Please Help my mp3 stops
Old 29th Dec 2006, 11:02 am
Default Please Help my mp3 stops
hi
my mp3 stops suddenly when i am listening mp3 and writes "WAITING...".
it do it when i am listening music but when i am listening FM, record something or doing something else it works normaly. i changed battery but doesn't help. if i need firmware can u tell me which firmware to download?
i have mp3:
Device name: Wilson co. ltd.
Product: s1 mp3 player
Version:
scd
sd51003a
2005/11/22
3.0.45
it's ID boar is: SD51002 V4 U3
thanks
happy new year and marry christmas
Old 29th Dec 2006, 2:00 pm
deathforever,
What capacity is your player?
It sounds like you may have some memory issues, try formating the player in fat format.
Do not try to upgrade or load another firmware it will most likely kill your player.
Old 31st Dec 2006, 12:42 am
Default Re: Please Help my mp3 stops
it's memory is 128MB
if i format it all data will be deleted so after that how can i write firmware?i don't have it
Old 31st Dec 2006, 12:54 am
deathforever, formating the player should not affect the firmware.
You could also run a disk check by right clicking on the player in Explorer and select Properties>Tools>Error Check with both options selected. This will correct any file system problems.
Old 31st Dec 2006, 6:27 am
i formated but didn't help
is there another way to solve this problem?
Old 31st Dec 2006, 6:59 am
What format is your music files you are playing?
Old 31st Dec 2006, 7:19 am
mp3 and some of them wma but mostly mp3
my mp3 player stops at starting RoBiNHooD Dead Players 0 1st Jul 2008 5:14 am
Video stops after 20 seconds - help! evans62 Video related 1 17th Oct 2007 8:02 pm
my MP4 player stops jef Support and How To 1 8th May 2007 3:35 am
vob conversion stops after 10min31sec hoghead Video related 0 1st May 2007 1:01 am
***Video Stops Suddenly!*** Joe Video related 6 18th Sep 2006 7:25 pm
