-   -   help for the mp4 dead (http://mympx.org/forum/dead-players/35708-help-mp4-dead.html)
nicodu78 29th Dec 2006 5:04 pm
hello (i am french :) )
i read the subject "Dead Player Recovery Guide" but I don't understand which pins i must link up together then you can indicate me the numero of the pins to link up
thank-you
SPECIFICATIONS:
Memory chip: SAMSUNG 646 K9G8G08U0M PCB0 4GB
Processor: ATJ2091N
Version: act2097_s72_1 2006/04/25 9.0.50 2006/10/30
http://www.s1mp3.org./images/mem_chip.png
arviverona 29th Dec 2006 8:17 pm
if you can erad the label "samsung..." upright..then go to the right side pins then stretch your tweezers about 1.2cm then try to short the pins randomly while your player is connected to the pc..the computer will eventually detect it after a while..like what tatad1 said in the recovery guide...its kind of random but dont worry it will not somehow damage your chip as long as you do not damage the pins or you might permanently shrt the pins so after doing so..check trhe pins if they are intact and aligned...
and let me ask.what website did you get the specs of the samsung chips?
tadad1 29th Dec 2006 8:27 pm
nicodu78, Your K9G8G08U0M chip is actually only a 1GB.
http://www.mympxplayer.org/samsung-a...rs-vt1692.html
If your player uses version 9.0.50 firmware and is dead you have very little chance of recovery at the moment as there are no tool compatible with this version firmware.
If none of the 9.0.XX version firmware in the Download section work for you then there may not be much you can do to fix your player.
http://www.mympxplayer.org/actions-9...mare-dc37.html
arviverona 29th Dec 2006 8:51 pm
i agree on tatad1 i have a friend that is the same version as yours and having hard time looking for it
nicodu78 30th Dec 2006 8:05 am
Re: help for the mp4 dead
http://www.s1mp3.org./fr/docs_deadrec.php
no I have transfer 2,5GB on my player :?
I can use the Full Version 9.0.48 for 1.5 LCD on my player?
http://www.mympxplayer.org/full-vers...lcd-df441.html
