NEED FIRMWARE FOR SANSUNG 643 & ATJ2098H NANOCLONE 9.0.4
Old 5th Jan 2007, 11:07 am
Default NEED FIRMWARE FOR SANSUNG 643 & ATJ2098H NANOCLONE 9.0.4
HI
I'VE A NANOCLONE
I BUY IT AS 4GB BUT IT IS ONLY 1GB (EBAY CHINA)
I TRY UPDATE THE FIRMWARE BUT NOW I HAVE ONLY A BLUE SCREEN
IT HAS SAMSUNG 643 MEMORY
WHIT ATJ2098H CHIP
ORIGINAL FIRMWARE 9.0.48
LCD 1.5" 65K
PLEASE HELP ME
SAY ME WHAT TO DO
I TRY TO INSTALL THE VERSION 9.0.48 FOUND HERE BUT IT IS WRONG AND I HAVE BLUE SCREEN
MY E MAIL: bozzolino1@vodafone.it
i need the correct firmware please
HEPL ME!!!!! : )
Old 5th Jan 2007, 12:47 pm
botti , have you tried the list provided by tadad1? They are here http://www.mympxplayer.org/some-9048...ds-vt2895.html
As currently the 9.0.48 firmware is not supported by the extraction tool, the available firmwares are very limited.
If you had tried those firmwares and still unable recover your player, then there is nothing much you can do until the extraction tool is able to extract full working firmwares.
Have a look in your cd, some cds comes with a firmware inside.
Old 5th Jan 2007, 3:58 pm
thanks
i try but nothing
my mp3 doesn't work
i can do anything?
thanks
Old 6th Jan 2007, 11:34 am
Default Re: NEED FIRMWARE FOR SANSUNG 643 & ATJ2098H NANOCLONE 9
please help me
someone have th same nano clone?
Old 7th Jan 2007, 2:12 am
botti , as mentioned earlier, this version currently is not supported by the firmware extraction tool.
So even if someone else has a working player with the exact same firmware, they can't extract the firmware because there is no tool to do so.
Problem getting s1res to import firmware:nanoclone w/ 9.1.54 richardwad1 Mods and Themes 8 30th Apr 2009 12:37 pm
Firmware for Tinydeal 8gb Nanoclone needed! Knasen Dead Players 2 7th Apr 2008 10:18 am
Firmware for Tinydeal 8gb Nanoclone needed Knasen Firmware 0 6th Apr 2008 5:36 am
NEED FIRMWARE FOR NANOCLONE WHIT ATJ2098H AND SAMSNG 643 botti Dead Players 0 5th Jan 2007 11:00 am
1.5" 1 gb nanoclone raz Video related 1 4th Sep 2006 8:37 pm
