I need proper firmware for ATJ2093H
Old 5th Jan 2007, 7:41 pm
Default I need proper firmware for ATJ2093H
my player is dead now.and it has only black screen and lıght.i tried some versions in this forum but still same problem.what can i do.what must i do.
ATJ 2093H
1,8 inch
version was:9.0.48
"ipod" writing on it
color is white
it has radio
:cry: :cry: :cry:
Old 5th Jan 2007, 11:10 pm
musty42 , the current firmware 9.0.48 has very limited firmwares available due to the extraction tool unable to support this version yet.
There is a list of v9.0.48 by tadad1 here http://www.mympxplayer.org/some-9048...ds-vt2895.html
If these do not work, then you need to wait til the extraction tool is available to support your player's version.
Try your cd, some cds comes with a firmware inside. Or you can try asking your seller to send you the firmware if he has any.
Lastly, please avoid triple posting. One post is enough to get replies.
Old 6th Jan 2007, 1:47 am
Default Re: I need proper firmware for ATJ2093H
Hi Lattesurf, What would the file extension on the Cd be?? if It had firmware??
My CD has a bunch of .msi files (languages) apart from drivers for win 98 and the utility tools including firmware updater (setup.exe)
directx 9
telephone book
win media player
also (vcredist.exe) ( InstMsiA.exe) ( InstMsiW.exe)
I assume with this version of FW updater does this still mean I can not upgrade my FW?? ops:
Cheers
Joffa
White Super i Platinum 2 GB
Logic Chip
ATJ 2093 H
F8200FA 59E
LKD 9702 01
2006 - 10 - 25
FW 9. 0. 48
2006 - 9 - 12
Memory
Samsung 640
K9LAG08U0M PCB0 FEI848AX
Battery 3.7v 180 mAh
USB 2.0 A to Hirose 4 pin flat
Old 6th Jan 2007, 6:17 am
joffa i think you have a player same with my player.could u send your player firmware to me,please. i tried everything but i cant be succes.if u send i will be very happy. thanks from now...
Old 6th Jan 2007, 10:20 am
Joffa , usually it'll either be .bin or .fw, have a search in it, you might be lucky.
ATJ2093H firmware been_1990 Firmware 0 13th Aug 2009 8:21 am
can not fid firmware for ATJ2093H yahallaq Firmware 0 11th Mar 2008 6:09 am
Proper battery care for a new unit Husker General Discussion 1 30th Oct 2007 9:03 am
Utility to format ebook txt to proper width? brokencase General Discussion 19 26th Mar 2007 6:56 pm
firmware for ATJ2093H essi75 Dead Players 2 27th Jan 2007 2:36 am
