No firmware works
Helo every one :
i have that fake ipod with 4 g.b memory and it was work good . but with some files the device restart . like everyone i made an ubgrade for firmware . and know the player not work at all . i tried all the firmware in recover mode of device (short som pins) but no one work good some of not work at all some of work in very dark screen ...in this time when i connect it to the computer the memory of player is 108 M.B and it is wrong the player is 4 G.B the boared number is MP-693C-SL MAIN V1.3 the chip number is hy27uf081g2m Thanks. |
yazan4all , the problem is currently you have yet to locate a compatible firmware for your player. You'll just need to keep trying until you get the right firmware.
You might also need to try other Full Firmwares as sometimes the combination of Full and Dump firmwares need to be correct. Regarding the memory issue, according to the Hynix datasheet, the hy27uf081g2m is only a 1Gigabit (128MB) chip. Your player had been hacked to show 4GB. The reason for your player restarts when you play some files is because of the hack. |
Re: No firmware works
so thanks but can you help me finding the right bin file of firmware with my information
yazan4all , you need to find out more information from your player. Like the processor's serial number (eg ATJ2085, ATJ2091).
This way, it would be easier to locate a likely firmware that you can try. |
again thank you for helping :
player information : fake ipod black color pro : atj285w mem : hynix hy27uf081g2m board no . : mp-693-c-sl main v1.3 2005.12.14 thank you again for your help. |
yazan4all , have a search in the downloads section. There are many ATJ2085 firmwares which you can use.
You need to try every single firmware for your screen size. |
hello:
i found firmware worked with device but nothing shown in the screen thanks |
and i have a quastion
whatis the meaning of dump and why the update program dose not accept the dump files thanks |
yazan4all , when you start the Upgrade Tool, does it detect your player?
If it does, then you need to try loading in dump files. Also, ensure that the dump files are repaired. http://www.mympxplayer.org/how-to-ex...tool-vt66.html Follow from step 12 onwards. Rename the dump file to dump.bin and click on repair.bat, after repairing, try to load in the new dump.bin again. |
| All times are GMT -7. The time now is 10:28 pm. |
