I need firmware to K9G8G08UOM
CRUOGLIO , according to the Samsung datasheet, Samsung K9G8G08UOM is a 8Gigabit (1GigaByte) memory chip, and not as advertised to be 2GB. The memory chip had been hacked to show 2GB instead.
You need to open the player again and look for the processor's number (eg ATJ2085 or ATJ2091). With this number, it would be easier to look for likely firmware in the downloads section. |
Re: I need firmware to K9G8G08UOM
thanks lattesurf, I open de reproducer and the model the processor is:
Nano-clone mod with File-Browsing Processor: ATJ2093H Memory: 1GB Samsung K9G8G08UOM firmware: LKD_9702_01 thenk for a new information.! |
CRUOGLIO , based on your chipset being ATJ2093, it'll be the 9.0.xx series.
Currently the firmware extraction tool does not support any versions higher than 9.0.43. Do you recall your original firmware's version? |
no, I do not remember, single memory the name: LKD_9702_01
CRUOGLIO , the downloads section has a list of the 9.xx series firmware http://www.mympxplayer.org/actions-9...mare-dc37.html
If none of these work, then there is nothing you can do until the extraction tool is available. |
| All times are GMT -7. The time now is 4:54 pm. |
