Help: Now showing 2 USBs!!!!!!!!!!!!
Old 7th Jan 2007, 1:01 pm
Default Help: Now showing 2 USBs!!!!!!!!!!!!
My fake SONY player details:
CORE: PMA 300_010
DATE: 2006-03-15
FW: SRX-3.5.37
DATE: 2006-03-24 (God knows what is true)
Memory chip: FBNM29B19K3WG (0636 & RFF written below)
Mother Board chip: ATJ2051H (FB314AB & 198 written below)
FM chip: TEA5767
Was advertized as 2 GB but played only 15 songs instead of 550. Formatting as FAT didn't help.So thought of upgrade.1st problem no firmware extract tool on this site worked on both my PCs running Windows XP & 2000. So decided to reload FW 3.5.37 not knowing about Motherboard but then 2 USBs were found & acted as only storage. Loading 3.0.41 led to ADFU device! Followed your Dead Recovery Guide & again 2 USBs! Pl. help!!!!!!!!!!!!!
Old 7th Jan 2007, 2:09 pm
Bobu, If the player is working go to the settings menu and select On-line Mode and check it is set to Normal Only.
If the player is not working but showing in Explorer you could use "lattesurf's" guide to remove the second drive.
Old 7th Jan 2007, 7:18 pm
or you can just remove all the files inside the usb and reformat only in one drive using the disk manager tool
Old 8th Jan 2007, 12:44 pm
Dear tadad1, my device is not even getting ON. So how to access SYS TOOLS MEMORY INFO after "lattesurf's" partition & encryption?
8GB player now showing 1GB memory petros0 Support and How To 8 27th Nov 2008 4:02 pm
Not showing up on pc stickystyle Dead Players 0 12th Oct 2007 1:12 pm
player isn't showing anything after upgrade jargrapes Dead Players 13 25th Feb 2007 10:45 pm
2GB player showing 1GB and bad sectors andy_267 Support and How To 1 7th Feb 2007 2:28 pm
512 showing 256 mb after formatting Chetan Dead Players 1 1st Aug 2006 10:32 am
