need firmware for sony clon mp4 player
originally there was 9.0.48 firmware
it has: -LX-2113-V1-91 -ATJ2097H chip -samsung 646 K9G8G08U0M PCB0 - 1 gb memory -no FM |
gr_alex , there is a list of v9.0.48 firmwares by tadad1 here http://www.mympxplayer.org/some-9048...ds-vt2895.html
If these do not work, then you have no choice but to wait until the extraction tool is able to support your version. |
Re: need firmware for sony clon mp4 player
gr_alex , then you don't have a choice but to wait until the s1fwx extraction tool is able to support your version. So that others with working players can extract them and upload to the forum for you to try.
Also, you can try asking your seller if they have the firmware to send to you. And try searching your cd, some cds have the firmware file inside. It'll usually be in .bin or .fw format. |
hello sir
i wana fw xd-669-key-v2 or xd-669-main-v2 proccessor ak1025 lcd zd932-f177-20rf24c-j081203 please urgently thanxxxx br zaheer |
hello sir
i wana fw t300-v4-090211 proccessor spmp3052b-hl171 lcd no number 3.5" thanxxxx br zaheer |
hello sir
i wana fw k918h2v3m proceesor ak1025 lcd bks1445b thanxx |
| All times are GMT -7. The time now is 11:31 am. |
