Not charging, displays hourglass and switches off
Old 18th Jan 2007, 5:14 am
Default Not charging, displays hourglass and switches off
Hi, I took delivery of a new 1gig MP4 player which arrived fully charged. It worked fine for one day until I thought it best to re-charge. Now, it simply won't work. The player is recognised OK by the PC and works great while connected - how useful is that? - and displays the charging animation, but as soon as it's unplugged, the screen flashes rapidly for a few seconds, displaying the hourglass before turning itself off completly - it won't switch back on.
Transfer of files works fine, I can read the firmware, every is OK other than no charging.
I haven't attempted any updates or other modifications.
I have dumped the firmware.
Any help appreciated - and yes, charging while the unit was switched on as per the instructions.
Thank you. Tony.
Old 18th Jan 2007, 6:15 am
greyrider , so basically the player works as per normal as long as it is connected to the computer via USB?
If so, it would likely be a faulty voltage regulator for charging inside.
As it arrived working with full charge, but is unable to recharge the next day, i would rule out a faulty battery.
i'll suggest you contact your seller for an exchange set.
Old 18th Jan 2007, 6:25 am
Default Re: Not charging, displays hourglass and switches off
Rats! I was hoping it might be something simple, that'll teach me to buy from a Hong Kong based seller
OK, I'll try but would think the cost of RMA might make it not worthwhile. Thanks for the quick response.
Old 18th Jan 2007, 7:31 am
Thought so, £15 to send the thing and it only cost me £7 + post originally, so it's for the round file - that's the bin. I'll buy a "real" one from a local electronics shop. It'll cost nearly four times as much but at least I can walk it back if there's a problem :cry:
Changing settings to English, switches back to Chinese after restart Loathly Support and How To 10 17th Nov 2009 5:33 am
date & time won't stay and switches off by itself Yam Support and How To 2 2nd Oct 2009 2:07 pm
Need source for microminiature switches for MP player stepher Support and How To 2 18th Jun 2009 11:48 pm
[solved] Displays only busy sign ??? sachitmaskey Dead Players 19 10th Feb 2007 7:06 pm
mp4 player often displays disk error man_utd Support and How To 5 31st Dec 2006 2:17 pm
