Dead MP4 Recovery - HELP
Old 22nd Jan 2007, 12:53 am
Default Dead MP4 Recovery - HELP
Hi, I was following the "Dead Player Recovery Guide" and unscrewed the back of the MP4 (mine only has two screws). The screen is on top of the chip and somehow attached. How do I get to the chip? I've tried to attach a photo, but not sure if it'll work (that's another question).[img]C:\MP4.jpg[/img]
Old 22nd Jan 2007, 1:56 am
upload your photo first on the ionternet and make a link here
Old 22nd Jan 2007, 6:08 am
Default Re: Dead MP4 Recovery - HELP
Hi arviverona or anyone else...
How do I go about uploading a photo on the internet? Have never done it before. Thanks
Old 22nd Jan 2007, 4:03 pm
MP4pic
Now trying to link uploaded photo of MP4 opened. Can't get to the chip as the screen is stuck in place on top of it. Has anyone got any suggestions?
Old 23rd Jan 2007, 12:07 am
try and try...but dont break your screen (or your player will be as useless like an ordinary flash drive with earphone)..you must be at reach to the CHIP to make the procedure.....
Old 23rd Jan 2007, 12:11 am
or the chip is under the battery (blue rectangle)..usually the chip is under the battery not the screen..usually the battery is placed witha foam tape..i have a suggestion..foam tape is hard to remove if you lift the object horizontally..try lifting from one corner then cpntinue until your about to lift the whole battery...
Old 25th Jan 2007, 3:14 am
Thanks Arviverona. But the battery is not on top of the chip. The battery is just sitting in there, held on by the wires. I can see the very edges of the chip under the screen and have tried making a connection with the two ends of a paper clip, but nothing happens (and yes, I have tried and tried). I'm assuming there's only one chip in there???
Old 25th Jan 2007, 3:39 am
melkel00, The screen is usually held in place with double sided tape and can usually be gently prised off. There are 2 chips a rectangular memory chip which will be the largest on the board and a smaller square main chip. You really need to have full access to the chip for the recovery process as it may help to know the serial number of the CPU.
What version was your original firmware?
Old 27th Jan 2007, 4:20 am
hes right..but be careful...
dead mp4/mp5 player recovery morgou Dead Players 8 9th Feb 2009 11:36 am
dead player recovery sharma2862 Dead Players 2 10th Nov 2008 9:10 am
help after dead recovery tehscreen still blank dunksall Dead Players 2 21st Nov 2007 3:44 am
Sigmatel Dead Recovery Guide! NguyenPhuc Dead Players 2 25th Sep 2007 1:29 pm
dead MP4 recovery for dummies jordipt Dead Players 2 10th Mar 2007 10:47 pm
