HELP... I can't recover my dead player
Old 22nd Jan 2007, 3:25 am
Default HELP... I can't recover my dead player
Guys can you kindly help me. i cant recover my dead player. i've tried thr dead recovery procedure here. at 1st attempt my player actually turns on. but after a while it turns off. and then on the second attempt to recover my player the player won't turn on. but i can hear a sound. a sound that when u put sa usb device on the computer when i'm trying to short circiut the player. But the computer cant recognize anything.What should i do?
Old 22nd Jan 2007, 4:24 am
sadclown, Is the player recognized by the firmware update tool?
Old 22nd Jan 2007, 4:39 am
tada1
nope the firmware update tool can't recognize anything. what should i do?
Old 22nd Jan 2007, 6:06 am
sadclown , if the Upgrade Tool fails to detect your player, then you will need to repeat the Dead Player Recovery guide again by shorting the pins. And get your player back into ADFU state before trying another Full and Dump firmware.
Old 23rd Jan 2007, 3:15 am
lattesurf
but even my computer can't detect a USB or ADFU.
Old 23rd Jan 2007, 4:54 am
Default Re: HELP... I can't recover my dead player
hey sadclown i have the same problem before.but i manage to solve it on my own
Try this one this might help you.
1. use different usb port. or unplug other usb device from your computer.
2. try to used different usb cable.because sometime even if you mp4 has been detected and charging on your computer when you try to recover a dead player using the usb cable you are using theirs a error message saying the usb usb is not properly connected.
3.if the computer manage to detect it install the device allow the computer to install and if the computer look for AdfuUd.sys try to find it at system32 on the WINDOS folder.
GOODLUCK nanlang sayo TOL sana gumana yan sayo!
Help recover my dead player CellTech HeyLe Dead Players 0 24th Jun 2009 12:04 am
how to recover dead player janda Dead Players 2 25th Feb 2009 7:13 am
How to: Recover a dead MP3/MP4 player admin Knowledge Base and FAQ 0 12th May 2008 1:12 am
Help me Please , I want to recover my dead mp4 player M_3oda Dead Players 2 24th Feb 2007 7:19 am
Dead Mp3 Player, need help to recover Herky85 Dead Players 0 9th Feb 2007 1:31 pm
