Need Firmware Sigmatel for Ipocket Inovix IKS
hi, first sorry for my inglish, i m spanish, i need lasted version of firmware sigmatel, mplayer is a Inovix Ipocket 2GB serial IKS, 15"
take phoo: http://www.tiendasupi.com/produc/04940016301.jpg Tanks. :) |
doble-h , is your player having any problems?
If your player is working fine and you just want to update the firmware version. I'll suggest not doing so. Sigmatel players are very difficult to recover if dead. And most cases need to be to factory reset. |
Re: Need Firmware Sigmatel for Ipocket Inovix IKS
My reproducer was not loaded in the current, and not folders, and took much to ignite, for that reason I wanted to change firmware to him. Somebody has one goes to him well?
I raise the program to extract firmware if somebody has the repruductor can extract and raise it it
http://www.megaupload.com/es/?d=68YXIDSC |
| All times are GMT -7. The time now is 9:51 am. |
