help me with that firmware
Old 24th Jan 2007, 6:58 pm
Default help me with that firmware
I Have fake sony mp4 player it is now dead and i need to get it`s flash ... plz help me ,,
board id is : MP-881C-TSLS
chip : ATJ2085H
thanks in advance
Old 25th Jan 2007, 3:17 am
Default Re: help me with that firmware
plz any body help me
Old 25th Jan 2007, 3:27 am
ahmedmph, If your player is not recognised by the MP3 Update tool then you will need to follow the Dead Player Recovery Guide HERE to reset the chip. It is not possible to tell you the exact firmware you will need to recover your player because there are so many variations produced by hundreds of manufacturers. I suggest you download as many firmware as you can find either 3.5.35 or 3.5.37 that suit your players screen size and try them till you find one that works with your player.
Old 25th Jan 2007, 4:59 pm
thanks man,
my mp4 player is recognised by the MP3 Update tool but ,, i tried alot of firmwares but it turns on and nothing appears on screen with blue light ,,,
i used the Full3.5.35 firmware , it gives me some shadows on the screen and i could run a mp3 file ,,
i need to fix this problem plz
Old 27th Jan 2007, 3:20 pm
chip : ATJ2085H
need firmware or suitable dump file plz ...
or tell me how to extract dumb file from another one
Old 27th Jan 2007, 3:44 pm
ahmedmph, Because there are so many firmware versions and generally when they are uploaded mainboard information etc is not included as most people who upload have not needed to open their player to find out these details, this makes it impossible to tell you which firmware are for which player specifications and what is going to work for you.
The ATJ2085H is one of the more common chips used so you have a better chance than most of finding a usable firmware. The only thing you can do is keep trying firmware till you find a match for your player.
