mp3 BlueScreeen Loading bug help
Old 27th Jan 2007, 5:15 am
Default mp3 BlueScreeen Loading bug help
hello, i've got problem with my mp3 player. I'll explain i charger my mp3 when it is finish i see the screenn is blue. i shut off. tomorrow when i want to open i've got the loading page blue and i can't see the menu. Please tell me what i need o do to resolve the problem. Thanks you so much.
Old 27th Jan 2007, 7:18 am
Default Re: mp3 BlueScreeen Loading bug help
know i need firmware please for that mp3 before i've got the problem i writhe the firmawre version
LSD89101-20
2006-10-21
9.0.50
Old 27th Jan 2007, 8:34 am
xsider , there are some v9.0.xx series firmwares in the downloads section here http://www.mympxplayer.org/actions-9...mare-dc37.html
However, the current firmware extractor can only work upto v9.0.43. So you need to wait till it supports your version if those in the downloads does not work.
If the player is still under warranty, i'll suggest you contact your seller for a replacement set.
Old 29th Jan 2007, 11:23 am
what i don't understand is that i charge the mp3 when it finish i saw the blue screen with the loading icon.I don't care at the moment but when i open the mp3 on the tomorrow i saw the same think. I try a lot off firmware i don't know what i need to make i know is the 9.0.50 my screen is 1.5. I dont- understand how could they put that firmware if with can't put with mp3 upgrade tool only until the 9.0.43 Please i need help :wink:
Old 29th Jan 2007, 10:50 pm
xsider , the MP3 Utilities Upgrade Tool was made by the manufacturers, so it can support any versions.
However, the S1fwx tool, which allows firmware extraction, is not made by the manufacturers. But created by wiRe of S1mp3.de.
This tool currently does not support any versions higher than v9.0.43, so someone with a working v9.0.50 cannot extract the firmware for you to try on your player.
Old 30th Jan 2007, 8:29 am
hi i know somebody who has got the same firmware can it possible i extract his firmware and put in my mp3. Please tell me if i is possible and what software did i need for the 9.0.50 thanks :wink:
Old 30th Jan 2007, 8:49 am
xsider , as mentioned previously, any firmwares with version above v9.0.43 cannot be extracted.
There are currently no tools available to extract the working firmware v9.0.50 out from the player.
Old 30th Jan 2007, 12:10 pm
So i need to wait the mp3 firmware extractor support the 9.0.50 version
or try a lot off firmware 9.0xx with mp3 upgrade tool :?:
Old 30th Jan 2007, 8:40 pm
xsider , in the current state of your player, i'll suggest just giving all those firmwares a try. If you're lucky, they might work.
If not, if it is still under warranty, get it replaced with your seller.
Unhappy MP4 keeps on Loading!!! chadski Dead Players 0 13th Oct 2009 3:03 am
loading problem VashTampiD Firmware 1 25th Sep 2009 4:21 am
Loading problem Itsimranarif Support and How To 0 25th Feb 2008 6:44 am
Loading Forever thejeswi.nk Support and How To 3 22nd Nov 2007 5:38 am
MP4 loading jake100 Support and How To 2 25th Apr 2007 5:52 pm
