help to a newbie!!
Old 29th Jan 2007, 3:42 pm
Default help to a newbie!!
Hi, i'm new to all this..
can anyone explain me these things:
1. how to make a full firmware backup of my mpx player?
2. how to change themes in my mpx player?
3. my nano clone won't boot up.. i looked int the recover guide but i can't open it.. u know... it has only 2 screws at the bottom ant that's it!..
here it's details: (fw):
fw:B806K8V2.0
date: 2006/11/08
core:9.0.48
date:2006/10/30
4. how can i get an hebrew firmware and/or make one on my own?
can u give me the tools for that and some explanation?
please help me!!...
thank's!!! great site + froum!! i looked for 1 like this for ages!
Old 29th Jan 2007, 11:20 pm
nirh216 , it is not possible to extract full firmwares from player, you need to do it in a factory-level. The S1fwx can only extract the firmware dump.
You can theme a player using the S1res tool. The guide is here http://www.mympxplayer.org/how-to-mo...ng-vt1719.html
After opening the 2 screws, using a thin blade, try to pry between the front and back casing around the player. You should be able to locate a few latches around it. However, these latches are usually very fragile and break easily, so be very gentle.
And lastly, unfortunately the S1fwx tool does not support the v9.0.48. It only supports a maximum of v9.0.43. However, if your player is dead, there are a few v9.0.xx series firmwares which you can try. The link is here http://www.mympxplayer.org/actions-9...mare-dc37.html
Hi. I'm a Newbie! dittoLIVE Miscellaneous 1 7th Dec 2009 3:07 pm
Help a newbie..I've about tried it all saltador Video related 2 4th May 2007 8:03 am
Please help newbie! anne_327 Mods and Themes 2 24th Mar 2007 7:13 pm
Hey Everyone. I am a newbie luiflores2 General Discussion 1 1st Feb 2007 4:26 am
Where do I start?(newbie) stefanyb General Discussion 2 14th Jan 2007 3:30 pm
