Dead MP3. Help!!! Upgraded With Wrong Firmware?
Pic: <img>
First Of All, I Forgot To Backup My MP3 (I know, Big Mistake) And I Tried To Upgrade My Firmware From 3.5.35 To 3.5.37 But After, The Screen Just Turned Red And Since, It Have Not Worked :( Please Help!!! |
bobrules, Is the player detected by Windows and the MP3 Update Tool?
The picture of your mp3 is not showing,what size screen does it have? |
Re: Dead MP3. Help!!! Upgraded With Wrong Firmware?
Another Note. The MP3 Player Is Not Turning On Either! Please Help!!!
bobrules, Ok , if the player is not being detected then you will need to do a hard reset by shorting the memory chip. This is outlined in the Dead Player Recovery Guide but you may find the guide at s1mp3.org better suited to your type of player. Although the guide we have here is exactly the same process it is done with a video enabled MP3/MP4 Player. have a read of this guide:
http://s1mp3.org/en/docs_deadrec.php#top s1mp3.org also has a larger selection of firmware for your type of player so you may have better luck finding a suitable replacement for you players original version. You will find their list of firmware here: http://s1mp3.org/en/downloads_fw.php The recovery process is not perfect as the hardware and firmware variations are many, your only option of finding a working version for your player is to try as many as you can find. In doing this your player may continue to need to be reset from time to time as it will no doubt stop responding again. Hope this helps and keep us posted of your progress. If you have more questions we will try to help as much as we can but the outcome really depends on being able to find a compatible firmware. PS check the mini cd that came with your player as sometimes a full copy of the firmware is included. It will be either a .bin file or a .fw file approx 4-5 MB in size. You could also email the seller as if he still has stock of the players he may be able to extract a dump for you from one of his players and send to you. This would greatly increase your chances of a full recovery. The extraction process is outlined here: http://www.mympxplayer.org/how-to-ex...tool-vt66.html s1fwx can be downloaded here if you need to give the seller this info. http://www.mympxplayer.org/s1fwx-31-df417.html |
Ive Opened Up My MP3 Player (Dissasembled) But I Cannot Find My Board ID. How Do I Find It?
bobrules, hard to say all players are different and some do not even have the board details on them.
I have some good news!
I Have Shorted The MP3 And Put It into recovery mode and installed a recovery FW And Im Now looking for the firmware i need. My Board ID Is MP-515E-GCFMV2 And My Chip Number (If You Need) Is ATJ2051W. The Lights On The MP3 Are Coming On (Red like Before) but no menu is showing so i still need the correct FW. If ANYONE can find the FW i need, Here is the Board ID and chip number again. Board ID: MP-515E-GCFMV2 . Chip Number: ATJ2051W . Please Help! |
hey pal tell me an upgrage for the following firmware
SC85051F 2006/04/25 ACI_v3.5.35 can i use the following SC85051A ACI_v3.5.35 |
nbhakuni , a word of advice is not to flash/upgrade your player with someone else's firmware. You will most likely end up killing your player.
| All times are GMT -7. The time now is 5:38 pm. |
