need nano clone 256 mb firmware
Old 29th Jan 2007, 9:38 pm
Default need nano clone 256 mb firmware
my flash memory is HY27OF082G2M HYNIX
Old 29th Jan 2007, 9:59 pm
martin0709, You may need to give a bit more info on your player. What was it's original firmware version? What type of player is it? Do you know the serial number of cpu, a smaller square chip something like ATJ2085, ATJ2097 etc.
Old 29th Jan 2007, 10:52 pm
I dont know the original firmware but the serial no. of cpu is ATJ2085H
Old 29th Jan 2007, 11:05 pm
martin0709, That is one of the most common chip types so the good news is that there are more firmware available that may help you recover your player. Unfortunatly it is not possible to tell you exactly which one will recover your player as there are many many versions. You need to be looking at version numbers 3.5.35 or 3.5.37 that match your players screen size.
If your player is still recognised by the MP3 Update tool then all you can do is keep trying different firmware till you find a suitable match for your player.
If your player is not recognised by the Update Tool then you will need to short the memory chip to do a hard reset and put the player into Recovery Mode. Have a read of the Dead Player Recovery Guide for details on how to do this.
http://www.mympxplayer.org/dead-play...ide-vt567.html
Old 16th Feb 2007, 1:01 pm
please post the photo of your mp4
and the board number if you can see
Please help nano clone 1.5" need firmware grafixmike Dead Players 0 13th Oct 2008 12:31 am
Need firmware for Nano clone mp3 player lukas_m Dead Players 1 7th Apr 2007 10:20 pm
I need Firmware 9.0.48 for ATJ2091H, Nano clone, 1Gb dr3am Dead Players 4 8th Feb 2007 12:36 pm
need nano clone firmware martin0709 Support and How To 1 1st Feb 2007 4:31 am
What firmware do you use on your Nano Clone dansvob General Discussion 2 19th Jul 2006 12:59 am
