[Half Solved] help!! mp4 2.0 dead!! need original firmware!
Old 31st Jan 2007, 10:22 am
Default [Half Solved] help!! mp4 2.0 dead!! need original firmware!
Please, need help urgently i have my player in recover mode (ADFU) but i can't find the original firmware. my mp4 2.0 inch player is this:
if any1 can tell me the brand or model or can helpme to find the original firmware please answer me.
the firmware that was originally 9.0.48 and chipset is ATJ2097H i think is like the palladium model from uxcell.
i've tried a lot of firmares from this site but no luck. Anyone know if there's any firmware that can boot it? Only black screen.
UPDATE: with mp3 player product tools 4.19 and one of the full 1.8 firmwares i am succed in revive the player. Now i'm able to see it in explorer with unit asigned.
But the problem begins when i want to install a full dump, because after install the dump with mp3 player utilities 4.09 i can't change anything from player. There is a write problem in flash, all settings that i modify don't save. I select spanish language, but when i go to menu, the settings are the same before. And if i go to player in explorer, there are a lot of files of 3gb size and total of 9gb!!!!! and i can't delete them.
i've tried to format the unit, but files are again and again. And when connect to a pc, it asks me again to format unit. Anyone knows what to do???any idea???
Old 31st Jan 2007, 7:45 pm
Default Re: [Half Solved] help!! mp4 2.0 dead!! need original firmwa
I'm using a 9.0.43 2.0 full dump, any idea???
Old 31st Jan 2007, 11:35 pm
xcarecrow , likely i think the problem lies with an incompatible firmware. As you have formatted the player, but still having the file problems.
You'll need to try another v9.0.xx firmware.
Try asking your seller if he has the firmware to send you.
Also search in the CD that came with your player, sometimes the firmware file is inside. It should be in .fw or .bin extension.
Old 1st Feb 2007, 4:43 am
i guess i have a full firmware on that
heres the link
for the full f/w
http://www.mympxplayer.org/firmware-...ull-df399.html
for the dump
http://www.mympxplayer.org/2inch-ver...ump-df459.html
good luck!
Old 1st Feb 2007, 6:00 am
Thanx for the reply, but the files i'm using are the same that you told me arviverona. there's nothing inside the cd of the player. I remember that the version that came with the player was 9.0.48. i think that i have to wait until a new version of s1fwx support the extraccion of that firmware.
Old 3rd Feb 2007, 4:54 am
have you tried s1fwx 3.1? i think there is a post in this forum that someone succesfully flashed his .0.48 firmware..
http://www.mympxplayer.org/yes-9048-...ed-vt3573.html
Dead mp4 player.Original Firmware needed!! Board:K9129H2V2M prymor Dead Players 0 6th Nov 2008 11:27 am
dead iPod nano clone ACU7515 9.1.51 original firmware purletpunk Dead Players 3 18th Apr 2008 8:31 am
It's half-dead UzY3L Dead Players 3 5th Jan 2008 5:35 am
half of the problem solved!!!! remolal Dead Players 1 11th Feb 2007 7:42 am
My half dead player ^^ Dead Players 12 14th Jun 2006 9:32 am
