MP4 player doesn't work, but works when connect to PC
Old 4th Feb 2007, 4:04 pm
Default MP4 player doesn't work, but works when connect to PC
when i turn on my mp4 player it didn't work. but when i connect it with usb cable to my computer it work perfectly. and when i remove the cable it turns off automaticaly. please help me.
Old 4th Feb 2007, 9:30 pm
it looks like a battery issue. Do you check if it's charging correctly?
Old 4th Feb 2007, 10:39 pm
I agree with f1blop, sounds like your battery is not holding a charge. Make sure the player is turned on at the main switch when you are charging it and give it a good 4 to 5 hours. You may also need to give it several charges. Do not use a USB hub either.
Old 6th Feb 2007, 2:34 pm
thank u f1blop and tadad1 but my mp4 use usb connection charging way not other connection to charge. please help me.
Old 6th Feb 2007, 3:20 pm
hamdos2007,
How long has this problem been happening?
If it's still under warranty, I would contact the seller and get it replaced as it seems to be a problem with the battery.
Also another possibility is the connectors are not soldered on completely to your player's board. Either way, if you can get it under warranty by the seller, that would be your easiest and best solution.
After updating firmware, screen works, but menu doesn't work korv Dead Players 2 7th Dec 2009 1:19 pm
[solved] Fake iPod Nano, works but wont connect on XP - 'unknown device' trebor_69 Dead Players 4 23rd Nov 2009 3:06 am
My MP4 player works fine, but certain things dont work! HELP George Samuel Support and How To 3 23rd Sep 2007 10:30 am
My player doesn't works right! HaPK Support and How To 2 22nd Feb 2007 7:19 pm
My player doesn't works right! HaPK Dead Players 1 21st Feb 2007 11:29 am
