Firmware Required "QY-781FV2 2006.12.31"
Old 6th Feb 2007, 12:19 am
Default Firmware Required "QY-781FV2 2006.12.31"
Hi There,
I Had One Mp4 Player with "ATJ 2091 H, Memory Hy27UTO84G2M TPCB, FM SP3767" With Board ID QY-781FV2 2006.12.31.
Earlier the Player was dead, in recovery mode. Later on after update now it is able to be detected on Pc as a USB Mass Storage Device.
It Currently Showing No Display Only Backlight when switching On & is detected on PC as a removeable device.
Please Help Me out.
Old 6th Feb 2007, 7:31 am
shubhanshu , your player would be running off the v9.0.xx series firmwares. Try all the firmwares in the downloads section here http://www.mympxplayer.org/actions-9...mare-dc37.html
Old 9th Feb 2007, 3:48 am
I Had Tried all the firmwares from the above link, But in vain. Please Suggest a different solution.
Thanks in advance
Old 9th Feb 2007, 4:25 am
shubhanshu , currently the firmware extraction tool can only support upto v9.0.43. Your player can be using the v9.0.43, v9.0.48, v9.0.50 or v9.1.50.
So there isin't much v9.0.xx firmwares. If the player is under warranty, contact your seller for an exchange. Also, try searching the CD that came with the player, sometimes the firmware is inside, it should be in .fw or .bin format.
There isin't much you can do currently except those i've mentioned.
Old 9th Feb 2007, 6:09 am
Default Re: Firmware Required "QY-781FV2 2006.12.31"
@ lattesurf
Thanks A lot for such a quick reply.
I also had one more problem. I Had one Mp4 Player, Arrived Basically dead. After firmware update, the player starts working but with no display, only backlight.
The player works fine without display.
Please Suggest Solution.
Thanks in Advance
Old 9th Feb 2007, 8:23 am
shubhanshu , is the second player also using the v9.0.xx series firmwares? The firmware you have flashed in is not fully compatible with your player, so it still functions, but the screen does not work.
If all the firmwares do not work, i'll suggest an exchange or refund for both of your players.
Looking for KJT-781FV2 31-12-2006 PY-1315W-1 1.48 2P RFD0711 MeDoOo87 Firmware 7 28th Feb 2010 3:00 am
Looking for Board: KJT-781FV2 2006.12.31 Chip: AK1025 swetha Firmware 1 19th Mar 2009 2:09 pm
Looking for plate QY-781FV2 2006.12.31 ATJ2091N amourben Firmware 0 30th Nov 2008 8:29 am
dumb for MP3/MP4 Model QY-781FV2 (2006-12-31) tchikyfalcon Dead Players 1 14th Aug 2007 8:59 am
Firmware Act_v3.5.35 2006/03/13 SC85052A required maakbar Dead Players 0 13th Jul 2006 11:55 pm
