Need help with MP3 Player Firmware
Old 6th Feb 2007, 8:34 am
Default Need help with MP3 Player Firmware
Hi... my story is the next one...
I have a MP3 Player of 2GB with FM and someday I make the mistake of format it with WinXP format tool... I lost the Firmware :cry:
I've allready read how to recover dead players and my windows now recognize my USB and the upgrade tool puts in recovery mode, but all firmware I've tried shows me "Flash is not responding"
I don't know my board ID, I've search in every part of it and can't find anything... I'll put the info I know about my USB...
Memory:
Samsung 622 K9WAG08U1M
PC80
AMP 2051
F4034AB 14A
FM Chip:
SP3767WN
The only clue I've found is that the board says "2006.01.06"
Here r some photos of the USB
When I try to Install a Firmware I get the message "Flash is not responding" and the display keeps blank, but when I try to install the ATJ2051 (FULL).bin the display changes and show 2 angels and some healing cross but still shows the message "Flash is not responding"
Thanks for all your help or tips
Old 6th Feb 2007, 8:53 am
Arael , i've only found 2 related firmwares for youe player, which uses the ATJ2051 chipset.
http://www.mympxplayer.org/mp-485e-m...are-df401.html
http://www.mympxplayer.org/firmware-v3043-df395.html
Try both of these firmwares. If they do not work, i'll suggest S1mp3.org at http://www.s1mp3.org/en/downloads_fw.php as they are dealing with more to the USB thumbdrive kind of player like yours.
Old 6th Feb 2007, 9:07 am
I tried with those two u put and neither of them work =(
One of them is a dump.bin... so I merge it with the ATJ2051 full I have... but id didn't work, the other one is a full, but don't even change the display...
