"DEVICE SWITCHING FAILED,RECONNECT THE DEVICE"
Old 7th Feb 2007, 1:23 am
Default "DEVICE SWITCHING FAILED,RECONNECT THE DEVICE"
[img]Click the image to open in full size.[/img]when i update mp4 player(LC-chineese)with wrong FW.it become dead.
when i update my mp4 player with another FW using mp3 player update tool its SHOWS a message like this:-
ICANT UPDATE MY PLAYER. BUT PLAYER RECOGONICE AS A REMOVE ABLE DISK .ICANT COPY ANY FILES TO THE DISK!. IT SHOWS A MSG LIKE THIS:-
"DISK WRITE PROTECTED! REMOVE WRITE PROTECTION"
WHAT CAN I DO?WHAT IS THE PROBLEM?
PLS HELP ME MY FRIENDS !!!!!!! [/url]
Old 7th Feb 2007, 1:27 am
remolal , try another version of MP3 Utilities Upgrade Tool. Uninstall the previous version and install a new copy.
Another method would be to use Product Tool 4.19 instead, it can be downloaded here http://www.mympxplayer.org/product-t...419-df234.html
Old 7th Feb 2007, 1:31 am
remolal, The last firmware you loaded was most likely for a player that has a Hold\Lock function and it is activated.
Try turning on the player at the main switch while holding down the play button, if that does not work repeat the operation again trying all the other buttons on your player.
If that still does not help download the Product Tool Here: http://www.mympxplayer.org/product-t...ads-df234.html
Use it to try and install another firmware, you will notice there is a format button if it becomes active press it to format your player, then try to load the firmware.
" Read or write device information failed!" wlazio2000 Dead Players 11 4th Apr 2009 5:41 am
"Device switching failed. reconnect device please" jaidagr8st Dead Players 19 23rd May 2008 6:06 am
"Read or Write device information failed" serp Dead Players 22 8th Aug 2007 12:57 am
Device switching failed, reconnect device please rakashmiri Support and How To 10 29th Dec 2006 7:25 am
[solved] Device Switching Failed, reconnect device please! Spawn_20240 General Discussion 5 2nd Aug 2006 6:44 pm
