mp4 firmware 9.1.50 BOCO_D15001E
Old 7th Feb 2007, 10:07 am
Default mp4 firmware 9.1.50 BOCO_D15001E
I need the firmware for my mp4. Please upload if anyone of you guys have that version. HELP!
The version that i have was updated on 12/15/206.
Old 8th Feb 2007, 1:19 am
Needhelp , i could not find any v9.1.50 firmware in the downloads section. However, there are the v9.0.xx series which you can try. http://www.mympxplayer.org/actions-9...mare-dc37.html
If they do not work, i'll suggest that you contact your seller if an exchange if it is still under warranty.
Also, you can try asking your seller if they have the firmware to send to you.
Search the CD that came with your player, sometimes the firmware is inside. It should be in .fw or .bin format.
Old 10th Feb 2007, 7:17 pm
Default Re: mp4 firmware 9.1.50 BOCO_D15001E
I've try already but isn't work. I have contact the seller but there's no respond back. My mp4 is a 4GB and look like a metallic nano. The color is blue. If anyone know what i'm talking about and have the firmware, please send to me at teng8461@yahoo.com.
