Need Firmware Suggestions
Old 11th Feb 2007, 1:12 pm
Default Need Firmware Suggestions
Chip on the back of my player reads:
Samsung 643
and on another chip reads:
ATJ2097H
Any firmware dump.bin ideas so I can get my player back online?
Old 11th Feb 2007, 1:57 pm
Vulpes, Your player is using one of the newer chips the ATJ2097, which means it would have had a 9.0.XX series firmware. In your other post you asked what a dump.bin is, it is a copy of the players firmware extracted with a tool called s1fwx. The problem you face is that at present s1fwx does not work on firmware above version 9.0.43, so if your player was using a 9.0.48 or 9.0.50 or above then there are no dump files available. If you have tried all the 9.0.XX series firmware in the Download section without any luck you may not be able to recover your player at present. A new firmware extraction tool is being developed but there is no word on when it could be released. Once it is released there will be a lot more firmware available that may help recover your player.
About to Buy? Suggestions? Fahout Support and How To 19 5th Jan 2009 1:48 am
Your suggestions admin Polls 19 23rd Oct 2007 3:30 am
Any Speaker Suggestions jtodd2823 General Discussion 4 22nd Feb 2007 8:46 am
How much video and suggestions mike78759 General Discussion 3 14th Feb 2007 5:09 am
Some Player Suggestions Miscellaneous 0 13th Mar 2006 3:09 am
