Need firmware 3.5.37 from 01/../07
Old 13th Feb 2007, 1:34 pm
Default Need firmware 3.5.37 from 01/../07
Who can help me i need the firmware. my player is dead.
please
Old 13th Feb 2007, 2:04 pm
I think its from 01/20.07
Old 13th Feb 2007, 2:16 pm
Default Re: Need firmware 3.5.37 from 01/../07
Old 13th Feb 2007, 2:39 pm
Herky85, Because there are so many firmware variations mad by so many manufacturers it is not possible to tell you exactly what firmware will work for your player. There are many 3.5.XX series firmware in the Download>Firmware section, you need to keep trying different ones until you find a compatible one. You could also try contacting your seller as they may be able to send you a copy.
Old 16th Feb 2007, 12:24 pm
please
if i can see the picture of your mp4 and also if you tell me the capacity i can send you the correct firmware
