PLEASe hELP ME nOW
Old 23rd Feb 2007, 12:58 am
Default PLEASe hELP ME nOW
my mp4 player is 1'8"
i upgraded it
from
Wilson Co.
Ver 9.0.48
2005-01-09
LSD-9312-10
2006-11-03
to
Wilson Co.
Ver 9.0.50
2005-01-09
LSD-9312-10
2006-11-03
then its not turning on
what should i do?
i opened the mp3 player upgrade tool again for it to check if theres a player connected .... then it showed the complete info of the version 9.0.50....
it has power now but i cant see the menu and all
its just plain white.....
what do u think happened???
Old 23rd Feb 2007, 1:21 am
Que Que is offline
No need to shout, or open several topics with the same question please. You killed your player for the moment because the firmware of your player, or newer firmwares, are not yet supported by the repair- and flash utility. So you flashed it with an un-repaired = incomplete firmware. You have to wait for a newer version of the upgrading software to revive your player.
