ATJ2091N firmware
Old 3rd Mar 2007, 2:13 pm
Default ATJ2091N firmware
I need firmware for ATJ2091N. I have "no name" :shock: mp3 player. On its board I found only this describtion:
A188 v2.0 2006.11.06 SZ?
Chip ATJ2091N
memory 256MB
If anybody could help me - here are my mail marjancz@o2.pl
thx
Old 3rd Mar 2007, 9:58 pm
marjancz , your player would be using the v9.0.xx series firmwares. i'll suggest trying all the v9.0.xx firmwares in the downloads section here http://www.mympxplayer.org/actions-9...mare-dc37.html
However, it is not possible to tell which firmware will work with your player, so try all those for your screen size.
If they do not work, try contacting your seller if they have the firmware to send to you. Also check the CD that came with your player, sometimes it is inside and should be in .bin or .fw format.
Old 5th Mar 2007, 12:51 pm
Default Re: ATJ2091N firmware
lattesurf, thx for help but unfortunatelly firmwares 9.x.xx don't work. I have tried few firmwares and few update tools, all have succes downloaded but my player is still dead. Now there is one good effect after download - my windows is recognizing a replacement disc. Once when I'm formmating this flash disk and re-connect to PC, windows displays: "disc isn't formatted. Do you want to formatt it now?". So maybe memory chip is damaged? How to check it?
P.S. My seller will not help me because he's cheat, thief etc., on my CD hasn't got any firmware.
Old 5th Mar 2007, 1:30 pm
I have that chip as well. I know that all the 9.0xx firmwares don't work. But I was able to get 3.5.7 to work. Granted I only have 256MB now. I have accepted this and am moving forward in my quest for a decent MP3 player.
"And remember; no matter where you go, there you are."
ATJ2091N firmware Zulu007 Firmware 2 16th May 2008 12:44 pm
looking for firmware, ATJ2091N qsb1121 Dead Players 2 25th Feb 2008 10:41 pm
Looking for firmware ATJ2091N Kulkuri Dead Players 0 26th Jan 2008 11:29 am
Please help me for my firmware - ATJ2091N fifou666 Dead Players 2 30th Oct 2007 8:18 am
i need firmware atj2091n for my mp3 youssef12 Dead Players 3 13th Mar 2007 5:17 am
