how to repair this mp4 player.... plz help
Old 4th Mar 2007, 4:37 am
Default how to repair this mp4 player.... plz help
i accidentally installed a wrong f/w and the result is it only got a white background(light on lcd). then i tried to install a firmware that i have downloaded. but the problem got worse... my pc does'nt detect it. so.. i tried to reset the memory as in the "dead mpx recovery guide" said. i got it back... now my pc detects it, but not fully normal because i cant get the suitable f/w for this mp4 player.... it doesnt have a board id.
[img]Click the image to open in full size.[/img]
this is a fake sony,..... can anyone help me fix this probelm and can tell the real name of this player?!!!...
thanks........
Old 4th Mar 2007, 7:33 pm
bammy3942875 , do you still remember your previous working firmware version number?
If it is v3.5.35, then try all the firmwares for your screen size here http://www.mympxplayer.org/actions-3535-dc15.html
If it is v3.5.37, then try here http://www.mympxplayer.org/actions-3537-dc16.html
And if it is v9.0.xx series, try these here http://www.mympxplayer.org/actions-9...mare-dc37.html
Old 5th Mar 2007, 6:43 am
Default Re: how to repair this mp4 player.... plz help
i finally got a firmware but the thing is... the button doesnt seem to be working!... whats the problem???... is there a way to fix this firmware??....
anywayz,.. thanks for the help...
Old 5th Mar 2007, 6:58 am
bammy3942875 , if it is the the v3.5.xx series, try using Waterlily software to reassign the buttons.
Old 6th Mar 2007, 5:53 am
what is waterlily software?... where can i download it?..... oh i forgot to tell that this mp4 has a speaker at the back... and its not working too...
repair sunplus mp4 player Kazama General Discussion 0 21st Oct 2008 6:33 am
I can't figure out how to repair my dead mp4 player BlooDAliance Support and How To 8 17th Oct 2008 12:49 pm
How to repair this TITAN 1GB MP4 PLAYER? marlsjk Support and How To 4 24th Sep 2007 11:43 am
New Player Dead. Can't repair Manhunter Dead Players 12 29th Nov 2006 11:50 am
MP3 player won't F/W update? (or repair) Leighton Williams Support and How To 1 30th May 2006 4:42 am
