Chinapod 2GB 1.5" dead - alternative firmware
Old 7th Mar 2007, 7:17 am
Default Chinapod 2GB 1.5" dead - alternative firmware
Hi Have got a 2gb Chinapod with 1.5" screen . Did say Lisong 9.0.50 before it messed up.
Does anyone know if an alternative firmware should run?
maybe 3.5.35???
Old 8th Mar 2007, 3:21 pm
danatkins , try all the v9.0.xx series firmwares in the downloads section here http://www.mympxplayer.org/actions-9...mare-dc37.html
Old 9th Mar 2007, 4:00 pm
After you reset, use the Full version of v3.5.35. Then use a v3.5.37 dump.bin and you will get it to work. At least that is what happened with my 1.5. The only problem with that version is it won't give me more than 256MB which actully sucks badly.
"And remember; no matter where you go, there you are."
Alternative fix for rockchip players you can try cpox10 Dead Players 0 16th Mar 2008 7:13 pm
Need Firmware 9.1.50 for "Chinapod" yesh Dead Players 19 20th Oct 2007 2:12 am
ZicPlay Trio ... looking for alternative Firmware forlistpb Support and How To 1 19th Sep 2007 6:31 pm
ChinaPod Frustration no-pro Support and How To 7 14th Apr 2007 8:24 am
CHINAPOD 1.8" fw 9.0.50 raz Support and How To 2 9th Apr 2007 9:04 pm
