Need Firmware 9.1.50 for "Chinapod"
Old 22nd Mar 2007, 11:28 pm
may i can use any other Firmware Version for my dead player?
Old 22nd Mar 2007, 11:29 pm
Honestly.. i haven't a clue when it'll be released. I do know that new version is currently under development and i believe tadad1 is testing/playing with a kind of 'beta' of it now.
No absolutely not. Don't even think about trying a different version of firmware. It will guarantee a dead player.
[hr:43af44b395]
Old 22nd Mar 2007, 11:35 pm
Shorty.. sorry.. i didn't know your player was already 'dead'.
Actually it is unlikely that a different version will work. If it is already 'dead' then you can try the "Dead Player recovery' tutorial and download the 9.0.48 version from the download section. Remember to follow it step by step.
Also this version is only for a dead player. If your mp4 works fine, don't use it.
[hr:43af44b395]
Old 22nd Mar 2007, 11:41 pm
Default Re: Need Firmware 9.1.50 for "Chinapod"
Yes I have 2 players, one is dead and i know how to get it in recover mode, but no firmware was working till now.
may you ask "tadad1" if i can get this test beta version?
i´m new here and i cant find him
I´m also not sure if the second dead one has the same fw inside before,
maybe it was anything like 3.5.3.7
do you know if there is any possibility to find out whats the right version for that player?
BR
Old 23rd Mar 2007, 12:05 am
Sorry i don't know what versions are used with various players. I wouldn't recommend trying the new software that tadad1 is using as he's reported several 'problems' with it and it seems it's not doing what it's supposed to do. All i can suggest is try a few different versions and see what happens. Always keep to the recovery tutorial... shorting out the pins on the chip after an unsuccessful update etc.
[hr:43af44b395]
  #16 (permalink)
Old 25th Mar 2007, 1:23 am
Hi Odyssey!
do you know how can i get in touch with "tadad1 "?
thanks
Shorty
  #17 (permalink)
Old 25th Mar 2007, 1:38 am
Shorty
This is the thread discussing the new software > http://www.mympxplayer.org/viewtopic.php?p=27117
Note that the software is still in development and may be of no use to you if you already have a dead player. You can leave a message there.
[hr:43af44b395]
  #18 (permalink)
Old 25th Mar 2007, 10:30 am
can anybody help myself?
I need the firmware (wilson.co ltd version 9.1.50)
  #19 (permalink)
Old 14th Oct 2007, 2:34 pm
Hi!
Is the topic actual anymore? I have the same fake-Ipod Nano und also need the 9.1.50 firmware. If you already have it.... please send it to me to!
Thanks!
  #20 (permalink)
Old 20th Oct 2007, 2:12 am
Hi!
I´ve got the same Player, are there any news about the Firmware or has somebody repaired the player with a 9.0.50 firm ?
greets
CHINAPOD 1.8" fw 9.0.50 raz Support and How To 2 9th Apr 2007 9:04 pm
Chinapod 2GB 1.5" dead - alternative firmware danatkins Dead Players 2 9th Mar 2007 4:00 pm
"Invalid upgrade firmware file" & "Flash AmitS Dead Players 1 26th Jan 2007 8:09 am
Firmware for "Digital Player MP4" 1.8" 2GB nabilash Dead Players 6 10th Jun 2006 4:27 am
