-   -   Need Firmware 9.1.50 for "Chinapod" (http://mympx.org/forum/dead-players/37111-need-firmware-9-1-50-chinapod.html)
yesh 8th Mar 2007 12:16 pm
That my player showed before I killed it...
mp3 player
lsd_9312_10
9.1.50
i hope anybody has the correct firmware for me.. ;-) Or any other version working on my player.
my player looks like this
http://i1.ebayimg.com/05/i/000/8d/43/15da_1.JPG
lattesurf 8th Mar 2007 3:19 pm
yesh , there are very limited v9.1.50 firmwares, as the extraction tool only supports upto v9.0.43 at the moment.
what i can suggest is to try all the v9.xx series firmwares here http://www.mympxplayer.org/actions-9...mare-dc37.html
If they do not work, try contacting your seller and see if they have the firmware to send to you. Also search the CD that came with your player, sometimes it is inside. It should be in .fw or .bin format.
yesh 9th Mar 2007 4:24 am
I already tried all the 9.0.xx firmwares, but not any of them worked with my player, I also tried all "MP3 Player Utilities" versions. On the CD, there are no Firmware files, I'll ask my seller for the new firmware.
thanks for "help" ;-)
otahom 10th Mar 2007 7:22 am
Re: Need Firmware 9.1.50 for "Chinapod"
hi YESH,
I have the same player like yours, my problem is when i play a video he play for 5 seconds and then the player blocked. Do you know how i can fixed this problem. By the way have you also the new firmware.
Please let me know of mail me.
Thanx
lattesurf 10th Mar 2007 8:41 pm
otahom , when you play music files, does it also stop after 5seconds?
It might be a problem with your amv encoding.
otahom 11th Mar 2007 11:09 am
Lattesurf,
I have a cd with the player en on that cd i have the converter . So i don't know how i can fixed this problem. Do i use another converter or what i have to do.
Thanx.
Shorty 22nd Mar 2007 10:23 pm
hi!
are there any news about that toppic?
I´ve the same china version of ipod 8GB - hacked Memory
one of that is dead and i need a full new firmware
LSD_9312_10 - 9.0.48
I´m not able to make an backup - dump of the second one which is still working
thanks
Shorty
Shorty 22nd Mar 2007 10:43 pm
duringg extract i get this error message:
"Das System kann nicht vom angegebenen Gerät lesen."
scan for devices...
detected drives: <j>
$j
connect to device 'J:\'...
init device...
set device to f-mode...
get info from device...
ic version = 0x7676
storage info = 0x0202, 0x0001, 0x0000, 0x0000
device = 'LISONG MP3 Player'
bootflash type = 'F644'
brom version = 3.0.80
firmware version = 9.0.48
read boot record...
detect firmware size...
error: Das System kann nicht vom angegebenen Gerät lesen.
read flash...
write to file 'dump.bin'...
filename = 'dump.bin'
filetype = afi
md5 = 9840EBC2E8400A2FB15F7153DFAB19D5
file id = 'AFI '
vendor id = 0x6977
product id = 0x6552
version = 9.0.48
date = 00/00/0000
| BRECF644.BIN | | 16kb | | F644 | | B | | A044CFFC |
| SYSINFO.BIN | | 192bytes | | | | | | AA778015 |
filetype = unknown
disconnect from device...
success.
Drücken Sie eine beliebige Taste . . .
may anyone kows the reason for that?
thanx
Shorty
_Odyssey 22nd Mar 2007 11:02 pm
Shorty... it's because the software you are using cannot extract version 9.0.48.
You have to wait for a new version of s1fwx to be written before you can do that
Shorty 22nd Mar 2007 11:22 pm
Hi Odyssey !
many thanks for your quick reply,
do you have any idea how long it will take for new version of s1fwx?
BR Shorty
