plzz help!!!
Old 9th Mar 2007, 2:40 pm
Default plzz help!!!
Hello!!
i need some help and i know that i can get it here!!
so i have mp4 player with 2 gb ... i think that it is ipod clone but i am not sure
here is some codes what is on my mp4 : ATJ209IH, samsung 643 and K9LAG08UOM!!
i have problem with my mp4 display....when i turn on it or connect with my computer the display is white! computer found player... everything is ok but display is white!!
i try to listen in phones and i heard radio!! so i think that mp4 not dead but someone can tell me how to get back normal display?!
plzz help!!
tnx
Old 9th Mar 2007, 5:12 pm
zirgz , if the player was not connected to the computer, does the display still show the white screen?
Also, did you update your player with any firmware?
Old 10th Mar 2007, 1:33 am
yes its always white!!
actually my mp3 was dead and on display was sandglass but then nothing don't work and i use dead player recovery guide in this page and after i do this
"Using the tweezers or other metal item gently make a connection between the pins on one side of the chip. I have found this can be quite random you may also have to do it a few times."
now i always have white screen....
and i upload some firmware and now on my mp3 is 9.0.48 firmware!!
do you know how to get back normal screen?!?!
Old 10th Mar 2007, 2:56 am
Default Re: plzz help!!!
zirgz,
if you did not have a backup of your firmware, you have to try to upload different dumped bin files on this site to your player. There is a little chance for success. Each time you upload an imcompatible bin file, you need tweezers for shortcircuit. Good luck.
Old 10th Mar 2007, 3:06 am
ok!! but what kind of dumped bin files i need?? it is 9.0.xx or waht?!
Old 10th Mar 2007, 3:14 am
I do not know, it depends on your chip model. you have to search for working dumped bin files for similar chipset from other users on this site.
Old 10th Mar 2007, 3:41 am
ATJ2091H ----> this is chipset??
Old 10th Mar 2007, 9:10 am
yea that is chipset code...u may need to find firmware that suit ur player...by trial and error method
waiting for exam results.
Old 10th Mar 2007, 9:36 am
what is trial and error method??
and you think that if i will find real firmware my mp4 display will be normal??
or my mp4 display is dead?!
Old 10th Mar 2007, 4:44 pm
zirgz , since your chipset is the ATJ2091, then your firmware would be the v9.0.xx series. Try all the v9.0.xx and hopefully one of them works for you.
I need back up files Of sunplus MP4 (pmp-704 v21.00)PLzz.... mahmoodhassani Dead Players 3 11th Sep 2008 6:23 am
plzz help me for mp4 player? agrajshree Dead Players 1 25th Jul 2008 6:13 am
Any One there To help me Plzz!! ganesh040 Firmware 6 18th Feb 2008 7:27 am
MP4 died on stand-by plzz help CaptainZap Dead Players 0 21st Nov 2006 2:31 pm
ATJ2085W 512 Samsung 616 v3.5.35,, HELP2 PLZZ piTFall Dead Players 2 3rd Nov 2006 8:04 am
