need original firmware dump.bin for mp4
Old 10th Mar 2007, 5:15 am
Default need original firmware dump.bin for mp4
Hi!! i have almost dead mp4 everything works but my display is white!!
does someone have dump.bin or original freeware for my player:
ATJ2091H
K9LAG08UOM
SAMSUNG 643
my mp4 looks like this one:
http://cgi.ebay.com/Black-2GB-Samsun...ayphotohosting
plzz help!! if someone have plzzz send to mee : x450@inbox.lv
tnx before!!
Old 10th Mar 2007, 9:37 am
sry about freeware...
i need original firmware!!
Old 10th Mar 2007, 6:17 pm
zirgz , your player would be using the v9.0.xx series firmwares which you can find in here http://www.mympxplayer.org/actions-9...mare-dc37.html
i'll suggest trying all of them.
As currently the S1fwx firmware extractor only supports upto v9.0.43 only, you might have problems looking for a suitable firmware.
If these in the downloads section do not work, try asking your seller if they have the firmware to send to you, and also search the CD that came with the player, sometimes it is inside and should be in .fw or .bin format.
I need original firmware for THIS? player Aiken Dead Players 2 2nd May 2009 2:32 pm
Heelp...i need at least the original firmware for this mp4. ipa_RELOADED Dead Players 0 5th Jun 2008 4:08 am
Help me to recover original firmware ABdigit Dead Players 4 31st Mar 2008 11:21 pm
why an ORIGINAL FIRMWARE 3.5.37 not start ???? Thierryd Dead Players 3 19th Dec 2006 6:05 am
My Mp4 does not recognize the original firmware. byteboyx86 Dead Players 8 29th Sep 2006 10:22 am
