ATJ2091N Dead player help
Old 17th Mar 2007, 8:18 am
Default ATJ2091N Dead player help
The second day after buying it was dead
IPOD CLONE
ATJ2091N
Samsung 649
K964GUO0A
1.8" Lcd
The MP3 player upgrade tool shows device description as
S1 Player
Wilson CO Ltd
Ver 9.0.48
I tried all downloads 4 9.0.x
one intresting thing that 4 all 9.0.x it doesn't accept the firmware file
while it did accept 3.5.35 showed sucess in the log but didn't worked
Old 17th Mar 2007, 5:33 pm
dhairyadand , as your chipset is ATJ2091, your firmware needs to be the v9.0.xx series. The "success" in the upgrade log only tells you that the firmware has been written into the player. It does not tell you if the firmware is compatible or not.
i'll suggest that you try other versions of MP3 Utilities that can be downloaded from the downloads section. Also try Product Tools.
Dead player, looking for ATJ2091N firmware deegopower Support and How To 1 31st Dec 2008 5:29 am
atj2091n mp3 player is dead computer doesn't recognize it ali44 Dead Players 1 10th Jun 2008 2:20 am
dead MP3 ATJ2091N krasio_dilov Dead Players 5 20th Mar 2008 5:10 am
Dead player - blank blue screen - atj2091n rnume Support and How To 0 10th Nov 2007 5:14 pm
Dead player, need right firmware atj2091n 9.0.50 zambo Dead Players 5 14th Oct 2007 1:40 pm
