another dead player rockchip base
Old 19th Mar 2007, 3:14 am
Default another dead player rockchip base
any has a frimware??? pm me if you have or send the firmware file to my
email adress dj_uneek_yeah@yahoo.com thanks in advance
Old 11th May 2007, 6:19 am
Default Re: another dead player rockchip base
im not speak english... speak spanish perfectly...
hi, i am have a this player = my original firmware version is damaged, version v.00.00.12 ..... dont search this firmware on the webs pages... you have a versions of the firmwares files???
Old 13th May 2007, 7:54 am
Hi i have a similar player if your player is dead u can flash this with http://rapidshare.com/files/24100443/Ver0.0.6.rfw
finding a firmware with exact button config is difficult but this will work.
only problem will be that your esc button will work as ok and vol up will become down etc.
i have also found a software that can change the boot screen and menu etc. the only thing left is a software for extracting firmware.
Also rockchip players are very stable u can easily update them. i have flashed it 10 -11times with wrong firmwares they either remain in upgrade mode so u can flash it with another firmware and once theplayer was showing the front menu but there were no sub menu so i was not able to put it in upgrade mode so i shorted the memory pins as u do with atj2085 player it went in recovery mode and i flashed it again.So i feel u can flash it ,it wont die easily
the software for changing boot screen is here
http://www.megaupload.com/?d=VI5SIQGJ
Old 13th May 2007, 1:37 pm
harshit - have you ever encountered the problem with the upgrade program that says 'too many bad blocks'? I upgraded the firmware about a week ago and it wasn't working right so I tried to reverse the upgrade but now it refuses to upgrade again, saying the error that I stated above. It's pretty frustrating.
Patching BASE.RKW on RK27xx series players. knob Mods and Themes 21 6th Dec 2009 5:59 am
Dead mp4 Fuzhou Rockchip player elmode Dead Players 0 2nd Apr 2009 12:43 am
Dead Rockchip IKO ET-UC40 player matasko24 Dead Players 3 3rd Jan 2009 3:34 am
Dead Rockchip Player avionik99 Dead Players 3 1st Jul 2007 8:04 pm
Rockchip player dead hmack15 Dead Players 2 24th Feb 2007 10:20 pm
