need help pls huhu
http://i19.photobucket.com/albums/b1...es/Image05.jpgi updated my mp4 then i turn tol dead mp4... someone help pls
it ATJ2085h SP3767HN hynix KOR hy27uf08262A i tried the reacovery manual but then it turn to blue screen wahuhu// its my fathers bday girf to me.. and i broke it... huhu |
Re: need help pls huhu
all the dump file i had downloaded is .7s how could i upload it to my mp4... i had try all the firmware on the downloads section.. some of them are succesguly uploaded to my mp4... but still it appers to be a blue screen. pls nid some advice thnks in advance!
http://i19.photobucket.com/albums/b1.../Image07-2.jpg email me : darylbrown2005@yahoo.com |
humaygush3026 , for your player, it would be using either v3.5.35 or v3.5.37 firmwares. i'll suggest that you try all the firmwares for your screen size in the downloads section here
http://www.mympxplayer.org/actions-3535-dc15.html http://www.mympxplayer.org/actions-3537-dc16.html As for the .7z extensions, they are actually compressed archives. So you'll need 7-zip software to uncompress them before you can use the dump file inside. Download here http://www.mympxplayer.org/7-zip-ver-431-df12.html |
i had tried all the firmware but it appers to be in blue screen...
i dont have dump files... i had no idea about it... i need your help badly |
Anyone pls help me ... just help me to find the the links... pls pls pls...
i found out that the samsung 662 mp4 has the same specs on my sony mp4... pls help me guyz... thnks |
erm , Its not a sony MP4 , its a cheap actionchipset player . Youll just have to keep searching for the right firmware - 3.5.35 or 3.5.37
| All times are GMT -7. The time now is 1:29 pm. |
