Need Firmware - MP4 Player with 4GB 2'' ACT2097_S75 9.0.48
Old 3rd Apr 2007, 1:32 pm
Default Re: Need Firmware - MP4 Player with 4GB 2'' ACT2097_S75 9.0.
Hello UNSAL
4 GB
2" TFT
chip Samsung 652 K9G8G08U0M
it was with firmware version: 9.0.48 (ACT2097_S75)
Can you send the firmware and the flash software to me and say to me how to make for repair my mp4?
My email is snoopy77@club-internet.fr
thank you very much.
Old 4th Apr 2007, 4:52 pm
UNSAL Your a GOD!
That firmware you sent me worked like a charm...
Finally.. FINALLY after months of having a useless MP4 player.. I can finally used it again.
Thanks Again.
BTW for information to others.
I used AMV tools 4.09
Memory Chip: Samsung K9G8G08U0M
Processor: ATJ2093H
Worked like a charm.
Old 9th Apr 2007, 8:17 am
I have the same mp3 player as AnTo, and i have the same problem, white screen
anyone please advice how to resolve the white screen problem
thanks
Old 10th Apr 2007, 10:02 am
I have the same problem with atj2093h so, if someone can send me ZX_923W_2[1].0Ling-in_061229.bin it would be helpfull
my email: tristounet61@hotmail.com
thanks
Old 10th Apr 2007, 1:02 pm
here is the link : ACT2093_S75 for Glacier or Glacier alike 2.0" player
this firmware saved 3 people up to now.
1. follow dead player recovery guide and make your computer detect your player as ADFU device.
2. Run mp3 player tool (I used 4.0.9) and select firmware upgrade
3. Select this firmware and then click recovery button (not upgrade, if its name is upgrae, something is wrong with step 1 or 2)
4. if Upload is successful, after your computer disconnect the player, remove it from computer and turn it on.
5. if everythign up to here is okay, then player will start with chinese language. Goto settings menu of player and then select 3rd menu(Language) and then select 2nd(English).
6. Good Luck, All.
  #16 (permalink)
Old 10th Apr 2007, 1:38 pm
here is my player : http://cgi.ebay.fr/ws/eBayISAPI.dll?...0293&rd=1&rd=1
so the firmware is not totaly adapted, but nom my player is alive thanks
(with a bad screen lol)
  #17 (permalink)
Old 10th Apr 2007, 5:13 pm
thank you Unsal
  #18 (permalink)
Old 4th May 2007, 6:25 am
hi everybody,
i have the same mp4 player $GB,2'',ACT2097_S75 ,firmware version 9.0.48 as Anto,but i don't have the same problem.some time ago ,while transfering some files on it ,some error occured,and now my player has some files i can't delete because windows recognizes them as corrupted,and every .amv,or mp3 file can't be recognized by my player.
Obviously,i have to reinstal my firmware,and i have dowloaded the version i think unsal has uploaded,but i'm reluctant to use it bacause my player is not dead ,it's just not working properly.if anyone had similar problem,or has the solution to mine,i would greatly appreciate if he/she could post it here or contact me at tarzanka@gmail.com
thank you
  #19 (permalink)
Old 4th May 2007, 7:14 am
tarzanka, all you need to do in this case is format your player. Try to use the mp3 disk utilities to do so and don't worry about firmware... it's not what is causing the problem. try to back up as much as possible if you'd like to keep it.
[hr:43af44b395]
  #20 (permalink)
Old 5th May 2007, 6:20 am
nop.i already tried that.the windows recognizes my mp4 player as a Removable Disk(:/G)(4GB-57MB) and Removable Disk(:/H)(57MB).It wont format any of them.
again,my player was working,up to some point ,properly,and then something happened,and now i have courupted files on it that i cant erase,and worse than that,every file copied on it cannot be read.
what should i do?
[solved] Looking for fware: ACT2097_S75 - 2006/09/06 9.0.48 xxMDxx Support and How To 4 23rd Jan 2009 12:05 pm
Dead player, looking for firmware ACT2097_S75 ver 9.0.48 chinjay68 Dead Players 14 27th Jul 2007 12:26 am
need firmware ACT2097_S75 ver 9.0.50 mikeg General Discussion 8 28th Apr 2007 12:15 am
