firmware problem
Old 6th Apr 2007, 5:42 pm
Default firmware problem
good day!... can anyone help me about this firmware here's the link...
this is the one that made my player alive.. but there's a problem, when i turn it on display comes up...but when it is on the menu display the button function doesn't work... is there's a way to fix this firmware.... Click the image to open in full size.
Old 7th Apr 2007, 1:56 am
bammy3942875 , what version was the firmware that you flashed it in?
Old 8th Apr 2007, 7:40 am
it's version was 3.5.37
Old 8th Apr 2007, 7:35 pm
bammy3942875 , try using Waterlily softeware here http://www.mympxplayer.org/waterlily...-mb-df256.html
Load the firmware into Waterlily and try to re-assign the buttons. Then re-load the firmware back into the player again.
Old 9th Apr 2007, 6:42 am
Default Re: firmware problem
i already use that software.. i uploaded that firmware but it doesn't have any button function on the system key tab... is there another way?...
thanks for the replies man..., i really appreciate it....
Old 9th Apr 2007, 6:47 am
Old 9th Apr 2007, 8:16 am
bammy3942875 , if you are unable to re-assign using Waterlily, then the firmware is not compatible with your player. You'll need to try another firmware again.
Problem for see me firmware Ak1025 djibrilcoulibaly Dead Players 0 19th Jul 2009 9:01 pm
ZX-6330N firmware problem Zulu007 Firmware 4 27th Apr 2008 4:36 am
mp4 problem ...and firmware leelaah Dead Players 0 22nd Jan 2008 12:33 pm
Please HELP Firmware problem ecastor Dead Players 6 19th Dec 2006 8:34 am
