Need Firmware! Please help me!
Old 7th Apr 2007, 12:37 pm
Default Need Firmware! Please help me!
My mp4 player (nono clone) doesn´t work, the display is blue... I tryed all the FW I found but nothing changed.
I think I need the 9.0.50 version for the ATJ2091N with Samsung 704 chip, 1.5" LCD-Display, 2GB and FM.
Please help me!
Old 7th Apr 2007, 10:17 pm
Simi , i'll suggest that you try all the v9.0.50 firmwares first here http://www.mympxplayer.org/actions-9...mare-dc37.html
If they do not work, then proceed to try other v9.0.43, v9.0.48, v9.1.50, etc.
Old 8th Apr 2007, 5:22 am
Default Re: Need Firmware! Please help me!
I tried all 9.x.x firmware for 1.5" LCD-display but nothing changed...
I need the right firmware, so if anybody has it please post it.
Old 8th Apr 2007, 7:33 pm
Simi , if those in the downloads section do not work, then there is nothing you can do. As the firmware extractor currently only supports upto v9.0.43, so anyone with a working v9.0.50 are unable to dump their firmware to upload to the forum.
i'll suggest that you contact your seller for an exchange if it is still under warranty.
