PC will not recognise my player anymore
Old 24th Apr 2007, 3:58 pm
mashimo,
Some USB cables are abit dodgy and when you have problems like this, it's best to try a few things first like changing the USB cable or connecting it to another computer/USB port just in case that's the issue.
Glad to see you have the problem solved though.
Old 26th Apr 2007, 1:35 am
Default Re: PC will not recognise my player anymore
i had put a wrong firmware to my mp4 and now it turn into white screen, and can't be detected by my computer.
How can i recover my mp4.
help me plssssssssssss
Old 26th Apr 2007, 3:54 am
Tried various PC's & OS's also Macs at the time. Was just a bit of luck I was in my Lads room and found his toy digital camera, (Made in China :roll: ) had the same connectors so WooHoo :P
Old 28th Apr 2007, 7:36 am
Hi Mashimo,
I am having the same problem with my uxcell MP3/MP4 player. My computer says it does not recognise the USB device. It worked once and I got 6 songs onto it but I am now stuck as to what to do. Can you help please?
Libbyuno
Old 28th Apr 2007, 7:44 pm
libbyuno , try using another USB cable. Usually the Windows message of "not recognising USB device" is a result of a faulty USB cable.
MP5 player won't start anymore correctly AllOutAnime Support and How To 0 4th May 2009 2:40 pm
Help: my computer is not recognizing my mp4 player anymore kalaslsl Support and How To 4 25th Apr 2009 7:02 pm
help my player wont open anymore =( jigoku Dead Players 1 18th Aug 2007 7:40 pm
Computer doesn't recognize MP4 player anymore sander0606 Dead Players 21 10th Aug 2007 10:44 pm
Player Cant Open Files anymore macko187 Support and How To 1 31st Mar 2007 6:42 pm
