PC will not recognise my player anymore
Old 15th Apr 2007, 3:25 pm
Default PC will not recognise my player anymore
Bought a cheapo MP3/4 player off ebay. Everything was working fine. XP detected it fine and I could play mp3's and converted amv's etc.
The player still works fine in that respect and plays the files on the memory. However Not one PC will recognise it any more. I can't access the player and it doesn't show up in My computer or device manager
I have NOT touched the firmware since I have had the player (currently - LSD_9101_20 2006-10-21 9.0.50 2005-01-09)
I plug the player into the pc (any pc) and the player itself shows the 'connected to pc' picture. I plug it into the charger and it charges.
I have even tried the recover a dead player procedure which did nothing for the player. :cry:
Please let there be someone who can help :?
Old 16th Apr 2007, 5:28 am
mashimo , you'll need to try all the v9.0.xx series firmwares here http://www.mympxplayer.org/actions-9...mare-dc37.html
As there is no way of telling which firmware would work properly with yours, i'll suggest that try all those for your screen size.
If still none works, you might want to contact your seller for an exchange or refund.
Old 16th Apr 2007, 6:25 am
Default Re: Help please
I cant get access to the player itself. No PC will detcet the player. The usb lead seems to work as the player tells me it connected to a PC or that it is charging and does charge it. So I cant access it to flash it with new firmware I have now tried to update the firmware using the player itself (I'll post pics of it when I get home tonight, with more details), when I chose update firmware it doesnt do anything just stays on the menu :x
I guess you get what you pay for when you buy cheap copies. Maybe the £20 would have been better put towards a reall Apple iPod
Old 16th Apr 2007, 10:14 am
The Player Front & Back
Screenshot
Samsung 701 K9LAG08U0M PCB0 FEL467X2
Old 17th Apr 2007, 12:50 am
UPDATE.
Fiddled about a bit and I can get my work computer (xp pro fully updated & sp2) to 'USB device not recognised' & 'A problem occured duing installation, your new hardware might not work properly'
I can get my home pc to do the latter too.
However still nothing in My Computer.
The quest continues.........
Old 17th Apr 2007, 3:30 am
mashimo,
How long have you had this player?
Is it still under warranty?
If you haven't touched it and all of a sudden doesn't get detected on your computer, I would say it's a hardware problem and you should get it sorted under warranty if you can. You can spend time trying to fix it, but it comes down to the physical hardware that's the fault (ie, the board or memory chip is faulty), then chances are you won't be able to fix it.
I've had a player like that before. It would 'look' like it's getting detected, but never showed up in Windows or get detected. I just swapped it under warranty as it shouldn't do that.
Old 17th Apr 2007, 4:24 am
Default Re: PC will not recognise my player anymore
Cant even get the bloody thing to turn on now :evil:
Doubt its under a warranty as I got it off ebay. I have emailed the seller requesting some after sales help, but nothing. Going by the really bad feedback on his last sales, looks like he's dumped that usernam and moved on to another to rip people off. Mp3_exp =http://feedback.ebay.co.uk/ws/eBayISAPI.dll?ViewFeedback2&userid=mp3_exp&ftab=Al lFeedback
When I bought it I didnt expect it to be as good as the real thing, but I guess keepin the money and buying an original would have been better.
You live and learn!
Old 17th Apr 2007, 4:58 am
:shock: Its back on again now. And the USB connected PC is charging it. Still no appearance in my computer yet, then again the unrecognised usb device prompt has stopped. :?
Going to try and source a new cable, unless anybody has a spare or one I can borrow (would be willing to cover postage and return) :wink:
Old 18th Apr 2007, 3:57 am
SOLUTION
Maybe :?
Trawling through Microsoft suport site. I have found that there is a problem with SP2 used on XP Pro/Home and the detection of USB devices. It doesnt look like there is a general rule as to what devices its having problems with, as it can be anything.
There is a 'Hotfix' available direct from Microsoft. It is still in testing apparently but can be obtained by request. They also advise that this may not solve the problem, and to wait untill the next available SP which will contain a permanent fix to the problem. Which is what I will probably do, as I am sick of this cheap crap. And then just give it to my kid.
Im going out to buy the real deal and not try and save a few quid buying crap like this again.
Old 22nd Apr 2007, 1:57 pm
Well mines sorted. We had a toy digital camera in the house with the same type of USB lead. Better quality than the crap that came with the fake nano :roll: Worked 1st time and still is :lol:
MP5 player won't start anymore correctly AllOutAnime Support and How To 0 4th May 2009 2:40 pm
Help: my computer is not recognizing my mp4 player anymore kalaslsl Support and How To 4 25th Apr 2009 7:02 pm
help my player wont open anymore =( jigoku Dead Players 1 18th Aug 2007 7:40 pm
Computer doesn't recognize MP4 player anymore sander0606 Dead Players 21 10th Aug 2007 10:44 pm
Player Cant Open Files anymore macko187 Support and How To 1 31st Mar 2007 6:42 pm
