Need firmware, ATJ 2093H, Samsung 704-K9G8G08U0M
My mp4 Sony S-970 not work, display blue screen
I need firmware for the ATJ2093H with samsung 704-K9G8G08U0M 1G 1.5" LCD,,,, Plese help me!!!! :( :( http://tranhieu.jamroll.net/soft/16042007032y.jpg |
ted7k , you'll need to try all the v9.0.xx series firmwares here http://www.mympxplayer.org/actions-9...mare-dc37.html
As there is no way of telling which firmware would work properly with yours, i'll suggest that try all those for your screen size. |
Hi lattesurf! Thanks for reply, I tried to upgrade v9.0.xx series firmwares here http://www.mympxplayer.org/actions-9...mare-dc37.html, but player not run, only Full Version 9.0.48 for 1.8 LCD
B806K1V2.0_2006-10-30_9.0.48.fw is run data, it can't play mp3 file, it also displayed blue screen, try help me again! Thanks so much! |
ted7k , if all the v9.0.xx firmwares do not work, then there is nothing you can do about it. As the firmware extraction software only supports upto v9.0.43 currently, others with working v9.0.48 & v9.0.50 are unable to dump their firmware to upload to the forum.
| All times are GMT -7. The time now is 9:32 am. |
