Problem in my player after update the Firmware
Old 28th Apr 2007, 5:05 am
Default Re: probem in my player after update the Firmware
thanks but how to install this.
Old 28th Apr 2007, 5:35 am
after Update the Firmware and format it
my player become only flash disk , blue screen.
Old 28th Apr 2007, 6:32 am
before i have done firmware upgrade i have found some hidden files on my player but when i do firmware ther are no this files on player.I have saved them can they be used somehow.How can I input picture here.
Old 28th Apr 2007, 6:36 am
If nothing can't be done can I give back player to the store becouse I have just bought it >Can they see that I have done firmware upgrade.
Old 29th Apr 2007, 11:56 pm
u may give it back to the store...if u still have the warranty
waiting for exam results.
  #16 (permalink)
Old 30th Apr 2007, 3:44 am
gandor , most users with Sigmatel players end up either sending the players back to the seller or just throwing it away. These players are extremely hard to recover due to the lack of tools, and usually need to be factory-reseted.
i'll suggest you contact your seller for an exchange or refund.
  #17 (permalink)
Old 30th Apr 2007, 6:10 am
same answer from gaboon........hey gaboon ur from malaysia! awesome!
  #18 (permalink)
Old 30th Apr 2007, 1:09 pm
Default Re: Problem in my player after update the Firmware
Yes I have
  #19 (permalink)
Old 13th May 2007, 8:53 am
I have found the solution it apears that the driver on my disc was bad ,but my fried has bought same player with newer firmware which works with my player that has 3500 sigmatel chipset.How can I upload driver to help some other guys that have same problem?
Are there any firmware update for this player SinnerSaint General Discussion 2 22nd Oct 2007 3:13 am
Would FW update help my Nanoclone battery draining problem ajh Support and How To 2 29th Dec 2006 12:59 pm
problem in it’s firmware during update murka Dead Players 1 14th Jun 2006 1:33 pm
Problem with Firmware Update Renan Support and How To 6 5th Apr 2006 6:39 pm
How to: Update the firmware for your MP3/MP4 player admin Knowledge Base and FAQ 0 24th Mar 2006 1:19 am
