Problem in my player after update the Firmware
I was try to Update the Firmware
but the player display no thing blue screen only and I haven't a backup dump . my player : 1Gb delux _atj2085w + samsung619 K9k8c08u8a I don't know abuot screen ( 1.5' or 1.8'). http://www.pcarm.com/productpic/1152079690.jpg help me please and thank you. |
updating a firmware is a risky job cos u can have the problems that u hav said.but i dont know how to reverse the updated firmware back.u might have to buy a new one.....
Re: probem in my player after update the Firmware
up
Yours look like the I-Nickle from uxcell try this firmware for it
http://www.uxcell.com/uxcell/retail/...ADS&action=faq Look for the I-Nickle and downloaded it. |
thanks joecool
but your link don't work. |
baa1425 , i'll suggest you try all the v3.5.35 firmwares here http://www.mympxplayer.org/actions-3535-dc15.html
And the v3.5.37 here http://www.mympxplayer.org/actions-3537-dc16.html As there is no way of telling which firmware would work properly with your player, you'll need to try all of them. Good Luck. |
yea...u need to try all 3.5.35 and 3.5.37..just reflash back ur mp4 with these firmwares...if lucky..u will find a compatible one to ur mp4
How can I install these firmwares because i have the same problem with firmware upgrade and blue screen .My player is neo m'sonic mp-02f 2GB i have got installation disc with him and I have installed sigmatel driver and with help of user manual i have done firmware upgrade and since than my player dont work but still can be used as flash memory please help.
gandor , there are only a handful of Sigmatel firmwares here http://www.mympxplayer.org/sigmatel-firmware-dc36.html
You might not be able to successfully recover your player as there are no tools available to extract Sigmatel firmwares. So others with working players could not extract and upload to the forum. |
thank lattesurf .
thank gaboon . now my player is only flash desk no player . and I ask abuot screen size . I don't know abuot screen ( 1.5' or 1.8'). and size of image ( 128 * 128 ) or anther . |
| All times are GMT -7. The time now is 6:16 am. |
