9th Aug 2007, 6:35 pm
hsals666 , if you have noticed, all the firmwares you have tried to use for recovering your player. Even if they used the same processor serial, or same version, some do not work.
Having the same exact version number, and the same exact player casing does not mean anything. The manufacturers changes hardware as they find cheaper alternatives, and they change the firmware to suit the hardware. But they do not practice proper versions control, and any changes to the firmware do not reflect any changes to the version number.
