Help me please! Ipod Clone MP3 Player!
Old 13th May 2007, 3:35 am
Default Help me please! Ipod Clone MP3 Player!
I have been trying many full firmwares to recover my dead player (in ADFU mode) . At most, what I can get is a blue screen, sometimes with some mere visible images, which are not clear. In short, those firmwares are unusable.
The specifications of my player are:
Chip: ATJ2085H F8066AB 591
NAND: HY27UF081G2M TPCB
LCD: CM60009ACT6-20060705
Board: MP-693C-SL MAIN V1.32005.12.14
It looks like this, exactly:
I think the compatible firmwares are ACT 3.5.35 or 3.5.37 only. Well, if someone have a FULL firmware, or a guide to recover THIS player, it would be great.
Help me please!
Old 14th May 2007, 7:20 am
thomas_hang0001 , there is no way of telling which firmware would work properly with your player. So you'll just need to keep on trying all the v3.5.35 and v3.5.37 firmwares until you get the right working one.
Old 14th May 2007, 3:14 pm
Default Re: Help me please! Ipod Clone MP3 Player!
I can't get the LOTUS flower version of full firmware.
I keep getting the Ipod user interface one, which my player isn't compatible. It shows dark blue with little unclear screen.
I'm finding the FULL lotus flower version, but not the Ipod interface version.
It looks like this:
http://img91.imageshack.us/img91/4017/jessnzfv2.jpg
... and how can I flash dumps into my player? Seems like the Updater Tools (v1.48~4.00) doesn't support flash dumps.
I did tried to repair the dump(downloaded) using s1fwx but it failed.
The dump is:
http://www.mympxplayer.org/firmware-3535-df289.html
Thanks for replying.
Old 14th May 2007, 6:08 pm
thomas_hang0001 , to flash these dumps into your player, you'll need to use MP3 Utilities available in the downloads section here http://www.mympxplayer.org/tools-dc10.html
Any version would work, but if one does not flash properly, uninstall and try another version.
It does not matter if the theme is lotus or ipod or any other themes. Once you get a firmware dump that works properly, you can always re-theme it to your liking.
Old 14th May 2007, 11:46 pm
I flashed some firmware v2.3.35. I can see something, but the things are just very dark, and sometimes the screen flickers.
It this the problem related to the firmware flashed? or the LCD screen?
Old 15th May 2007, 1:59 am
(Sorry, double post)
Old 15th May 2007, 5:12 am
thomas_hang0001 , you can try using Waterlily software to edit the firmware contrast that appears dark on your player. Download here http://www.mympxplayer.org/waterlily...-mb-df256.html
If it still does not work, most likely the firmware is not fully compatible with your player as the screen driver might not be compatible.
Old 15th May 2007, 7:46 am
Why is it in SCD Format! I need BIN, or FW!!! Why?
XP doesn't see my iPod Clone/FM/Camera Player ludichris106 Support and How To 2 29th May 2008 2:25 am
need firmware for iPod Clone MP4 Player ACT 9.0.50 !!! morahicoss Dead Players 0 17th Dec 2007 5:00 am
need firmware for iPod Clone MP4 Player !!! morahicoss Support and How To 0 14th Dec 2007 9:33 am
mp4 player (ipod clone 1go) is dead fred_81dz Dead Players 7 6th Dec 2006 2:10 am
Dead player / 2GB iPod clone bianchidavide Dead Players 5 7th Aug 2006 4:57 am
