Help with a dead player
Old 5th Jul 2007, 2:25 pm
Default Help with a dead player
Hello, I think my player has died. I have been plugging in and out the USB cable, because I tested AMV Converter and I was transferring movie files, and after I finished and plugged out the cable.. it wouldn't turn on anymore. I must add that I am always stopping the USB device before I plug out the cable!
Now, if I try to charge the player from the power supply, the screen will turn white. And that's it.
I have a nano 2nd gen clone, firmware 9.0.50.. what can I do to restore it?
Thank you for any help :cry:
Old 6th Jul 2007, 1:34 am
w00t,
Can your computer still detect your player as a drive? If it can, what you can try do is backup your files, then FORMAT your player.
If that doesn't work, then extract the firmware from your player and then flash your player again with your extracted firmware (use only YOUR firmware).
Hope that helps.
Old 6th Jul 2007, 2:33 am
Hello,
Windows will not detect the player anymore..I insert the cable and nothing happens.
Plus I cannot extract the firmware because it's one of those versions that cannot be extracted at the moment.
Old 7th Jul 2007, 12:17 am
Default Re: Help with a dead player
Anybody knows what should I/can I do?
And what caused this malfunction?
I found out that my firmware is in fact 9.0.48.
Digital player
LX93001_A
2006/12/08
ACT_V9.0.4x
Old 9th Jul 2007, 1:07 am
Ok it is clear that I have to apply the 'dead player recovery guide'. I have read it a few times and I am going to give it a try, but first I have to ask something:
1. Considering the version I have (or had).. Digital player, LX93001_A, 2006/12/08, ACT_V9.0.4x; after I write a full firmware, will this info still be the same?
2. If I write a full version will I still have to use 9.0.48? Or am I free to use other versions like 3.5.37 or 9.0.43. After all, if i completely rewrite the firmware, I could do this, no?
edit: from what I have read right now, it seems I could do this.
3. Also, if I write the full firmware, I could upload themed firmwares, no?
My player is the Ipod Nano 2nd generation clone with a 1.8" screen. I will also upload pictures when I get home.
edit: pictures: Pic1 Pic2 Pic3 Pic4 Pic5 Pic6 Pic7
Chip is Samsung, serial number K9L8G08U0M, PCB0
Old 9th Jul 2007, 1:36 pm
I doubt my questions are so difficult... yet no one seems to help me anymore..
Old 12th Jul 2007, 1:16 pm
I cannot reset the player in ADFU mode! I have short circuited the chip over and over, the flame can sometimes be seen, but windows will not detect anything! What should I do?
And what happened to tadad...
Old 13th Jul 2007, 1:44 am
brother i have five mp3 payaer but i insert the player in usb is says found new hardware but not accept any driver plz help me i m in trouble
MP4 DEAD THIS IS THE CPU AND BOARD POST, DEAD PLAYER manikakoto Dead Players 0 9th Feb 2009 3:08 pm
Dead Player i think very dead... DzoniHSV Dead Players 13 10th Aug 2007 12:13 am
dead player, so very very dead Kosh Dead Players 4 1st May 2007 6:48 am
Dead well almost dead MP4 Digital Player Zest Dead Players 6 28th Jul 2006 9:59 pm
