-   -   Looking for firmware: ACT_V3.5.35 2006/09/06 cm600009v1-6k (http://mympx.org/forum/dead-players/38173-looking-firmware-act_v3-5-35-2006-09-06-cm600009v1-6k.html)
sushantvirdi 7th Jul 2007 5:12 am
I need a firmware upgrade for my mp4 player. It has a 128*128 screen.
Here are other details i found in the firmware details section in my mp4 player.
MP3 Player
cm600009v1-6k
2006/09/06
ACT_V3.5.35
Is a firmware upgrade available for this player?
Please help me...
Thanks.
_Odyssey 7th Jul 2007 6:26 pm
sushantvirdi,
Probably not.. you should back up your existing firmware version with s1fwx first before you start mucking around with your 3.5.35 firmware.
Why do you want to upgrade anyway?
Updates for these players rarely exist and you can't use any one elses firmware because they would be incompatible. A firmware upgrade won't make it do magical new things.. not even to play new files or run faster... it will most likely kill it.
The only thing you could do is extract and modify your current firmware to give it a different look.
How to Extract > http://www.mympxplayer.org/how-to-ex...tool-vt66.html
How to Modify > http://www.mympxplayer.org/how-to-mo...ool-vt206.html
Oh and if you don't mind.. please share your firmware with us.. it may help restore someones dead player.
sushantvirdi 8th Jul 2007 2:36 am
Re: Need a firmware upgrade for my mp4 player..
Thanks for details...
As for the firmware sharing i will definately share it with u guys...
Also i want to add new themes to my player...Is it possible? If yes which tool i have to use?
_Odyssey 8th Jul 2007 5:15 am
You're welcome
Theming your firmware is the same as 'Modifying' using 's1res' at this link: How to Modify > http://www.mympxplayer.org/how-to-mo...ool-vt206.html
Your firmware can be extracted, themed and flashed back to your player safely. Be sure to keep a backup of your original firmware and only theme a copy of it.
