need firmware please help
Old 18th Jul 2007, 9:43 pm
Default Re: need firmware please help
Having already opened my case. You need to remove the center buton its only stuck on with double sided tape of some kind same with the screen cover. Then you nee to push carefully on the inside guts of the player once you have moved it a few millmiters you will need to remove the white plate I dont know how to do this bit at i broke mine but once you remove it the rest of the guts will silde out the top.
How do I find out which firmware I should be useing for my mp3/4 player I have one that is ment to be 4 gig and its not working proply but I found out the number off the chip and it says its an 8 gig one I need new firmware how do I find out which one?
Old 19th Jul 2007, 6:17 am
vash8, you do not need to take it apart. I'm pretty confident it's the same player as I bought from hailitele.
Board number: BO-018*
**2007*01*28VER: C**
Chip: ACU7503
G2023CA 528
Memory: Samsung 722
K9G8GO8UOM
PCBO
FEE217PAC
Pictures can be seen here
and my post about the same player is here
kallek
Old 19th Jul 2007, 8:29 am
I have to do dead player recovery because my screen keeps flickering and stuff and it's like not staying connected to computer it stays connected maybe for a second then goes away
Old 19th Jul 2007, 8:34 am
So tell me how to take it apart without breaking it
Old 19th Jul 2007, 11:25 am
Ok,
Take out the two screws in the bottom. Remove the "bottom plate", the plastic piece held in place by the screws. Push the board upwards, sliding it through the alu. casing. This requires a bit of force, but I have done it several times without anything breaking, so you should be fine. Be careful with the glass. It is semi-glued on to the rim of the LCD, and it will probably come off as you slide the board through the casing. That's ok, just keep track of it.
I followed the instructions here
kallek
  #16 (permalink)
Old 16th Aug 2007, 3:24 am
So any updates for this player? I have the same one from CD-R KING
http://www.cdrking.com/local/product...410849-2488327
  #17 (permalink)
Old 22nd Oct 2007, 8:27 am
i have the exact same player(only in black) and cant find which fw i can use to fix it.
When i use the update disk tool it always says invalid fw file.
any help?
