IT's ALIVE, IT's ALIVE
  #31 (permalink)
Old 7th Aug 2007, 2:18 am
Originally Posted by alex2pb
Hi scatwell . Thanks for the link. If it's ok I can add it to my glacier and alike repair guide. About the hack, I did a little bit of research and in my opinion it's not the sellers that hack the firmwares. It seems that the factory does that. Here's why I think that: The firmware is made by a few files which are all put in 1 file. Those files are mainly the music player, the recorder, the radio, etc. Those are all the programs the main kernel executes when you access the menu items. Somewhere between these files, there's the bootloader and a driver (I guess) that holds the flash type. The kernel (the main program) loads this driver and executes it. Now, depending on the chip inside, it will choose the proper driver program for the flash. Here's the tricky part. Whoever produces these players and has the sourcecode for the firmware, forces the kernel to load a higher capacity flash driver and the player reports a higher capacity.
I am still trying to get the firmware out from the clone file, but I am not sure it's possible. I'll report back if i get it to work.
Thanks again for the clone file.
I'm sure you're correct that the factory puts the hack in. It's also quite likely the sellers do not have any links to the firmware fixes/upgrades.
I'm hoping to receive a 550MB file which is an s1clone of the dehacked player. Not sure how I will get it to you if it arrives but maybe it'll zip down smaller.
Thx for your interest. Good luck with trying to extract f/w.
  #32 (permalink)
Old 7th Aug 2007, 11:19 am
Default Re: IT's ALIVE, IT's ALIVE
That's nice. I suggest you use 7-zip to pack the file. I compressed a ~200 mb file down to 8 mb with it. What you need is to use the ultra level and put the dictionary to 48 mb or bigger (but you'll need a good computer with lots of RAM memory). Here I couldn't even move the mouse while compressing (only 384 mb of ram).
Btw, good news, I found 2 new glacier firmwares and one of them is 9.1.5.1 . I'll make those available as soon as I can.
  #33 (permalink)
Old 8th Aug 2007, 12:12 am
hi im having problems recovering my mp4 player
because when i try to press the recover firmware button in mp3 update tool it stops and says "Read or write device information failed! Please exit the program and check if device is connecting!" sometimes "Flash Is No Responding" and "Unknown Flash Error" what should i do?
ive tried so many version of mp3 player utilities
  #34 (permalink)
Old 8th Aug 2007, 3:20 am
S1clone will be compressed & uploaded as soon as I get it (if I get it!). In meantime, any chance of the 9.1.51 - is it full version?
  #35 (permalink)
Old 8th Aug 2007, 10:00 am
Yup, I added it and other 3 new firmwares in the guide and uploaded it. You should get RevC from the downloads section.
@hsals666
Read "Issue3" in the guide i made.
  #36 (permalink)
Old 8th Aug 2007, 10:11 am
where is the guide?
  #37 (permalink)
Old 8th Aug 2007, 11:27 am
Here it is: Glacier Repair Toolkit RevC.
  #38 (permalink)
Old 8th Aug 2007, 11:47 am
what is the revc for?
the guide is for glacier only?
  #39 (permalink)
Old 8th Aug 2007, 11:55 am
RevC means revision c, that is the version of the guide.
Portions of the guide may apply to different players too...For example Issue3 applies to all players. But the firmware in the pack not. That is only meant for Glacier and alike players, so don't use it if you have a different one.
  #40 (permalink)
Old 8th Aug 2007, 9:37 pm
okay i let you know if the guide helped me..thanks
I'm sitll alive! geostar Miscellaneous 2 26th Oct 2009 12:20 pm
Mp3 dead, storage alive!! HELP!! RedFox Dead Players 3 3rd Apr 2007 5:40 pm
iRiver E10 needs firmware or something for to be alive Jes Dead Players 1 19th Mar 2007 9:09 pm
IT`S ALIVE! Donkez Dead Players 9 1st Jun 2006 11:10 am
A dead player can be alive downloader99 Dead Players 1 3rd Apr 2006 1:57 am
